Datasheet AD8519, AD8529 (Analog Devices) - 4
Description8 MHz Rail-to-Rail Operational Amplifier
Pages / Page16 / 4 — AD8519/AD8529. Table 2. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
RevisionD
File Format / SizePDF / 403 Kb
AD8519/AD8529 Table 2 Parameter Symbol Conditions Min Typ Max Unit
AD8519/AD8529
VS = 3.0 V, V− = 0 V, VCM = 1.5 V, TA = 25°C, unless otherwise noted.
Table 2. Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS AD8519AKS, AD8519ART 700 1200 μV −40°C ≤ TA ≤ +125°C 900 1400 μV AD8519AR (R-8), AD8529 700 1100 μV −40°C ≤ TA ≤ +125°C 1200 μV Input Bias Current IB 300 nA Input Offset Current IOS ±50 nA Input Voltage Range VCM 0 2 V Common-Mode Rejection Ratio CMRR 0 V ≤ VCM ≤ 2.0 V, −40°C ≤ TA ≤ +125°C 55 75 dB Large Signal Voltage Gain AVO RL = 2 kΩ, 0.5 V < VOUT < 2.5 V 20 V/mV RL = 10 kΩ 20 30 V/mV OUTPUT CHARACTERISTICS Output Voltage Swing High VOH IL = 250 μA 2.90 V IL = 5 mA 2.80 V Output Voltage Swing Low VOL IL = 250 μA 100 mV IL = 5 mA 200 mV POWER SUPPLY Power Supply Rejection Ratio PSRR VS = 2.5 V to 7 V, −40°C ≤ TA ≤ +125°C 60 80 dB Supply Current/Amplifier ISY VOUT = 1.5 V 600 1100 μA −40°C ≤ TA ≤ +125°C 1300 μA DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ 1.5 V/μs Settling Time tS To 0.01% 2000 ns Gain Bandwidth Product GBP 6 MHz Phase Margin Φm 55 Degrees NOISE PERFORMANCE Voltage Noise Density en f = 1 kHz 10 nV/√Hz Current Noise Density in f = 1 kHz 0.4 pA/√Hz Rev. D | Page 4 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION MAXIMUM POWER DISSIPATION PRECISION FULL-WAVE RECTIFIER 10× MICROPHONE PREAMP MEETS PC99 SPECIFICATIONS TWO-ELEMENT VARYING BRIDGE AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
