Datasheet OP162, OP262, OP462 (Analog Devices) - 3
Description15 MHz Rail-to-Rail Operational Amplifiers
Pages / Page20 / 3 — Data Sheet. OP162/OP262/OP462. SPECIFICATIONS. Table 1. Electrical …
RevisionH
File Format / SizePDF / 476 Kb
Data Sheet. OP162/OP262/OP462. SPECIFICATIONS. Table 1. Electrical Characteristics Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Data Sheet OP162/OP262/OP462 SPECIFICATIONS Table 1 Electrical Characteristics Parameter Symbol Conditions Min Typ Max Unit
link to page 3 link to page 3
@ VS = 5.0 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 1. Electrical Characteristics Parameter Symbol Conditions Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS OP162G, OP262G, OP462G 45 325 µV –40°C ≤ TA ≤ +125°C 800 µV H grade, –40°C ≤ TA ≤ +125°C 1 mV D grade 0.8 3 mV –40°C ≤ TA ≤ +125°C 5 mV Input Bias Current IB 360 600 nA –40°C ≤ TA ≤ +125°C 650 nA Input Offset Current IOS ±2.5 ±25 nA –40°C ≤ TA ≤ +125°C ±40 nA Input Voltage Range VCM 0 4 V Common-Mode Rejection CMRR 0 V ≤ VCM ≤ 4.0 V, –40°C ≤ TA ≤ +125°C 70 110 dB Large Signal Voltage Gain AVO RL = 2 kΩ, 0.5 ≤ VOUT ≤ 4.5 V 30 V/mV RL = 10 kΩ, 0.5 ≤ VOUT ≤ 4.5 V 65 88 V/mV RL = 10 kΩ, –40°C ≤ TA ≤ +125°C 40 V/mV Long-Term Offset Voltage1 VOS G grade 600 µV Offset Voltage Drift2 ∆VOS/∆T 1 µV/°C Bias Current Drift ∆IB/∆T 250 pA/°C OUTPUT CHARACTERISTICS Output Voltage Swing High VOH IL = 250 µA, –40°C ≤ TA ≤ +125°C 4.95 4.99 V IL = 5 mA 4.85 4.94 V Output Voltage Swing Low VOL IL = 250 µA, –40°C ≤TA ≤ +125°C 14 50 mV IL = 5 mA 65 150 mV Short-Circuit Current ISC Short to ground ±80 mA Maximum Output Current IOUT ±30 mA POWER SUPPLY Power Supply Rejection Ratio PSRR VS = 2.7 V to 7 V 120 dB –40°C ≤ TA ≤ +125°C 90 dB Supply Current/Amplifier ISY OP162, VOUT = 2.5 V 600 750 µA –40°C ≤ TA ≤ +125°C 1 mA OP262, OP462, VOUT = 2.5 V 500 700 µA –40°C ≤ TA ≤ +125°C 850 µA DYNAMIC PERFORMANCE Slew Rate SR 1 V < VOUT < 4 V, RL = 10 kΩ 10 V/µs Settling Time tS To 0.1%, AV = –1, VO = 2 V step 540 ns Gain Bandwidth Product GBP 15 MHz Phase Margin φm 61 Degrees NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.5 µV p-p Voltage Noise Density en f = 1 kHz 9.5 nV/√Hz Current Noise Density in f = 1 kHz 0.4 pA/√Hz 1 Long-term offset voltage is guaranteed by a 1000 hour life test performed on three independent lots at 125°C, with an LTPD of 1.3. 2 Offset voltage drift is the average of the −40°C to +25°C delta and the +25°C to +125°C delta. Rev. H | Page 3 of 20 Document Outline Features Applications General Description Pin Configurations Revision History Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Functional Description Offset Adjustment Rail-to-Rail Output Output Short-Circuit Protection Input Overvoltage Protection Output Phase Reversal Power Dissipation Unused Amplifiers Power-On Settling Time Capacitive Load Drive Total Harmonic Distortion and Crosstalk PCB Layout Considerations Applications Circuits Single-Supply Stereo Headphone Driver Instrumentation Amplifier Direct Access Arrangement Outline Dimensions Ordering Guide
