Datasheet OP184, OP284, OP484 (Analog Devices) - 10
DescriptionSingle-Supply Rail-to-Rail Input/Output Operational Amplifier
Pages / Page24 / 10 — OP184/OP284/OP484. 300. VS = 5V. 270. TA = 25°C. AV = +10. 240. AV = …
RevisionJ
File Format / SizePDF / 685 Kb
OP184/OP284/OP484. 300. VS = 5V. 270. TA = 25°C. AV = +10. 240. AV = +100. 210. (V p. G IN. 180. DANCE. 150. P M. 120. UT P. M O. UT O. MU XI. S = 5V. AV = +1
OP184/OP284/OP484 300 VS = 5V 270 TA = 25°C AV = +10 240 AV = +100 210 (V p G IN 180 DANCE 150 P M 120 UT P M O UT O MU XI S = 5V AV = +1
OP184/OP284/OP484 300 5 VS = 5V 270 TA = 25°C AV = +10 ) 240 -p 4 Ω) AV = +100 210 (V p ( G IN 180 3 DANCE SW E T 150 P M PU I T 120 U 2 UT P M O 90 UT O MU XI 60 1 V MA S = 5V AV = +1 VIN = 0.5V TO 4.5V 30
023 026
RL = 2kΩ TA = 25°C 0
00293-
0
00293-
10 100 1k 10k 100k 1M 10M 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 23. Output Impedance vs. Frequency Figure 26. Maximum Output Swing vs. Frequency
300 30 V V S = 15V S = ±15V 270 T V A = 25°C IN = ±14V R 25 L = 2kΩ 240 TA = 25°C Ω) 210 ( A 20 V = +100 AV = +10 180 DANCE E (V) 150 P T 15 M U I 120 VO UT P 10 90 UT O 60 5 30
024
AV = +1 0
00293-
0 10 100 1k 10k 100k 1M 10M 1k 10k 100k 1M 10M
027
00293- Figure 24. Output Impedance vs. Frequency Figure 27. Maximum Output Swing vs. Frequency
300 180 VS = 3V AV = +10 TA = 25°C 270 TA = 25°C 160 AV = +100 240 140 Ω) 210 ( 120 180 100 B) DANCE d E 150 P 80 VS = ±15V M RR ( I 120 CM 60 UT P 90 UT 40 O VS = +3V 60 20 VS = +5V AV = +1 30
025
0
028
0
00293-
–20
00293-
10 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 25. Output Impedance vs. Frequency Figure 28. CMRR vs. Frequency Rev. J | Page 10 of 24 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Functional Description Input Overvoltage Protection Output Phase Reversal Designing Low Noise Circuits in Single-Supply Applications Overdrive Recovery Single-Supply, 3 V Instrumentation Amplifier 2.5 V Reference from a 3 V Supply 5 V Only, 12-Bit DAC Swings Rail-to-Rail High-Side Current Monitor Capacitive Load Drive Capability Low Dropout Regulator with Current Limiting 3 V, 50 Hz/60 Hz Active Notch Filter with False Ground Outline Dimensions Ordering Guide
