Datasheet AD815 (Analog Devices) - 8
DescriptionHigh Output Current Differential Driver
Pages / Page16 / 8 — AD815. 700. 1400. G = +10. 600. 1200. 500. 1000. SIDE B. SIDE A. G = +2. …
RevisionD
File Format / SizePDF / 589 Kb
AD815. 700. 1400. G = +10. 600. 1200. 500. 1000. SIDE B. SIDE A. G = +2. 400. 800. +TZ. 300. –TZ. (PER AMPLIFIER) 200. SINGLE-ENDED SLEW RATE – V. 100. 200
AD815 700 1400 G = +10 600 1200 500 1000 SIDE B SIDE A G = +2 400 800 +TZ 300 –TZ (PER AMPLIFIER) 200 SINGLE-ENDED SLEW RATE – V 100 200
AD815 700 1400 5 G = +10
600 s 1200 s /
4 500 1000 SIDE B SIDE A G = +2 3 400 800 +TZ SIDE A 300 600 2 –TZ (PER AMPLIFIER) 200 400 SIDE B 1 SINGLE-ENDED SLEW RATE – V 100 200 DIFFERENTIAL SLEW RATE – V OPEN-LOOP TRANSRESISTANCE – M 0 0 0 0 5 10 15 20 25 –40 –20 0 20 40 60 80 100 OUTPUT STEP SIZE – V p-p JUNCTION TEMPERATURE –
C
Figure 22. Slew Rate vs. Output Step Size Figure 25. Open-Loop Transresistance vs. Temperature
–85 15 V V S =
15V S =
15V SIDE B –80 14 RL = 150
+PSRR +V SIDE A OUT | –V –75 13 OUT | +VOUT RL = 25
PSRR – dB –70 12 SIDE A OUTPUT SWING – Volts | –VOUT | SIDE B –65 11 –PSRR –60 10 –40 –20 0 20 40 60 80 100 –40 –20 0 20 40 60 80 100 JUNCTION TEMPERATURE –
C JUNCTION TEMPERATURE –
C
Figure 23. PSRR vs. Temperature Figure 26. Single-Ended Output Swing vs. Temperature
–74 27 –73 26 –72 VS =
15V RL = 50
–71 25 –VOUT –70 +VOUT CMRR – dB 24 –69 –CMRR OUTPUT SWING – Volts –68 23 +CMRR –67 –66 22 –40 –20 0 20 40 60 80 100 –40 –20 0 20 40 60 80 100 JUNCTION TEMPERATURE –
C
Figure 24. CMRR vs. Temperature Figure 27. Differential Output Swing vs. Temperature REV. D 7– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION MAXIMUM POWER DISSIPATION Typical Performance Characteristics THEORY OF OPERATION Choice of Feedback and Gain Resistors PRINTED CIRCUIT BOARD LAYOUT CONSIDERATIONS POWER SUPPLY BYPASSING DC ERRORS AND NOISE POWER CONSIDERATIONS Other Power Considerations Parallel Operation Differential Operation Creating Differential Signals Direct Single-Ended-to-Differential Conversion Twelve Channel Video Distribution Amplifier OUTLINE DIMENSIONS Ordering Guide Revision History
