Datasheet AD8013 (Analog Devices)
DescriptionSingle Supply, Low Power, Triple Video Amplifier
Pages / Page13 / 1 — Single Supply, Low Power,. Triple Video Amplifier. AD8013. FEATURES. PIN …
RevisionA
File Format / SizePDF / 358 Kb
Single Supply, Low Power,. Triple Video Amplifier. AD8013. FEATURES. PIN CONFIGURATION. Three Video Amplifiers in One Package
Datasheet AD8013 Analog Devices, Revision: A
a
Single Supply, Low Power, Triple Video Amplifier AD8013 FEATURES PIN CONFIGURATION Three Video Amplifiers in One Package 14-Pin DIP & SOIC Package Drives Large Capacitive Load Excellent Video Specifications (RL = 150
V
) Gain Flatness 0.1 dB to 60 MHz DISABLE 1 1 14 OUT 2 0.02% Differential Gain Error DISABLE 2 2 13 –IN 2 0.06
Differential Phase Error DISABLE 3 3 12 +IN 2 Low Power +V 4 S AD8013 11 –VS Operates on Single +5 V to +13 V Power Supplies +IN 1 5 10 +IN 3 4 mA/Amplifier Max Power Supply Current High Speed –IN 1 6 9 –IN 3 140 MHz Unity Gain Bandwidth (3 dB) OUT 1 7 8 OUT 3 Fast Settling Time of 18 ns (0.1%) 1000 V/
m
s Slew Rate High Speed Disable Function per Channel Turn-Off Time 30 ns
differential gain and phase error of 0.02% and 0.06°. This
Easy to Use
makes the AD8013 ideal for broadcast and professional video
95 mA Short Circuit Current
electronics.
Output Swing to Within 1 V of Rails
The AD8013 offers low power of 4 mA per amplifier max and
runs on a single +5 V to +13 V power supply. The outputs of
LCD Displays
each amplifier swing to within one volt of either supply rail to
Video Line Driver
easily accommodate video signals. The AD8013 is unique
Broadcast and Professional Video
among current feedback op amps by virtue of its large capacitive
Computer Video Plug-In Boards
load drive. Each op amp is capable of driving large capacitive
Consumer Video
loads while still achieving rapid settling time. For instance it
RGB Amplifier in Component Systems
can settle in 18 ns driving a resistive load, and achieves 40 ns (0.1%) settling while driving 200 pF.
PRODUCT DESCRIPTION
The outstanding bandwidth of 140 MHz along with 1000 V/µs The AD8013 is a low power, single supply, triple video of slew rate make the AD8013 useful in many general purpose amplifier. Each of the three amplifiers has 30 mA of output high speed applications where a single +5 V or dual power current, and is optimized for driving one back terminated video supplies up to ± 6.5 V are required. Furthermore the AD8013’s load (150 Ω) each. Each amplifier is a current feedback amp- high speed disable function can be used to power down the lifier and features gain flatness of 0.1 dB to 60 MHz while offering amplifier or to put the output in a high impedance state. This can then be used in video multiplexing applications. The AD8013 is available in the industrial temperature range of
G = +2 0.2 R
–40°C to +85°C.
L = 150
0.1 0 500mV 500ns VS =
5V 100 –0.1 9 V 0 S = +5V –0.2 –0.3 NORMALIZED GAIN – dB –0.4 1 0 –0.5 0% 5V 1M 10M 100M 1G FREQUENCY – Hz
Fine-Scale Gain Flatness vs. Frequency, G = +2, R Channel Switching Characteristics for a 3:1 Mux L = 150 Ω REV. A Information furnished by Analog Devices is believed to be accurate and © Analog Devices, Inc., 1995 reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or
Tel: 617/329-4700 Fax: 617/326-8703
