Datasheet OP193, OP293 (Analog Devices) - 2
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 2 — OP193/OP293. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 1/15—Rev. C …
RevisionD
File Format / SizePDF / 411 Kb
OP193/OP293. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 1/15—Rev. C to Rev. D. 9/09—Rev. B to Rev. C. 1/02—Rev. A to Rev. B
OP193/OP293 Data Sheet TABLE OF CONTENTS REVISION HISTORY 1/15—Rev C to Rev D 9/09—Rev B to Rev C 1/02—Rev A to Rev B
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 8 link to page 8 link to page 8 link to page 9 link to page 13 link to page 13 link to page 14 link to page 14 link to page 14 link to page 14 link to page 15 link to page 15 link to page 15 link to page 16 link to page 16 link to page 17 link to page 18 link to page 18
Features .. 1 Input Overvoltage Protection ... 14 Applications ... 1 Output Phase Reversal—OP193 ... 14 General Description ... 1 Output Phase Reversal—OP293 ... 14 Pin Configurations ... 1 Battery-Powered Applications .. 14 Revision History ... 2 A Micropower False-Ground Generator ... 15 Specifications ... 3 A Battery-Powered Voltage Reference ... 15 Electrical Specifications ... 3 A Single-Supply Current Monitor .. 15 Absolute Maximum Ratings .. 8 A Single-Supply Instrumentation Amplifier .. 16 Thermal Resistance .. 8 A Low Power, Temperature to 4 mA to 20 mA Transmitter ... 16 ESD Caution .. 8 A Micropower Voltage Controlled Oscillator .. 17 Typical Performance Characteristics ... 9 Outline Dimensions ... 18 Functional Description .. 13 Ordering Guide .. 18 Driving Capacitive Loads .. 13
REVISION HISTORY 1/15—Rev. C to Rev. D
Changes to Figure 3 to Figure 6 ... 9 Changed Minimum Output Voltage Swing High Parameter Changes to Figure 10 and Figure 12... 10 from 4.0 V to 3.9 V; Table 2 ... 4 Changes to Functional Description Section and Figure 26 .. 13 Changes to Ordering Guide .. 18 Deleted A Micropower, Single-Supply Quad Voltage Output 8-Bit DAC Section .. 13
Deleted Figure 13; Renumbered Sequentially .. 14 Updated Format .. Universal Deleted A Single-Supply Micropower Quad Programmable- Deleted OP493 .. Universal Gain Amplifier Section .. 14 Changes to Features and General Description Sections .. 1 Changes to Output Phase Reversal—OP293 Section, Battery- Deleted 8-Lead Epoxy DIP Pin Configurations for OP193 and Powered Applications Section, and Figure 27 .. 14 OP293, and 14-Lead Epoxy DIP and 16-Lead Wide Body SOL Deleted Figure 14 .. 15 Pin Configurations for OP493 .. 1 Changes to Figure 31, A Single-Supply Current Monitor Changes to Offset Voltage Parameter and Large Signal Voltage Section, and Figure 32 .. 15 Gain, RL = 100 kΩ, −10 V ≤ VOUT ≤ +10 V Parameter, and Changes to A Low Power, Temperature to 4 mA to 20 mA Power Supply Rejection Ratio Parameter, Table 1 .. 3 Transmitter Section and Figure 35 ... 16 Changes to Offset Voltage Parameter and Power Supply Updated Outline Dimensions ... 18 Rejection Ratio Parameter, Table 2 .. 4 Changes to Ordering Guide .. 18 Changes to Offset Voltage Parameter and Power Supply
Rejection Ratio Parameter, Table 3 .. 6 Changes to Offset Voltage Parameter and Power Supply Deletion of Wafer Test Limits Table .. 5 Rejection Ratio Parameter, Table 4 .. 7 Deletion of Dice Characteristics Images .. 6 Changes to Table 5 and Table 6 ... 8 Edits to Ordering Guide ... 6 Rev. D | Page 2 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
