Datasheet OP193, OP293 (Analog Devices) - 5
DescriptionPrecision, Micropower Operational Amplifiers
Pages / Page20 / 5 — Data Sheet. OP193/OP293. E Grade. F Grade. Parameter. Symbol. Conditions. …
RevisionD
File Format / SizePDF / 411 Kb
Data Sheet. OP193/OP293. E Grade. F Grade. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
Data Sheet OP193/OP293 E Grade F Grade Parameter Symbol Conditions Min Typ Max Unit
Data Sheet OP193/OP293 E Grade F Grade Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
NOISE PERFORMANCE Voltage Noise Density en f = 1 kHz 65 65 nV/√Hz Current Noise Density in f = 1 kHz 0.05 0.05 pA/√Hz Voltage Noise en p-p 0.1 Hz to 10 Hz 3 3 μV p-p DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 12 12 V/ms Gain Bandwidth Product GBP 35 35 kHz 1 Long-term offset voltage is guaranteed by a 1000 hour life test performed on three independent lots at 125 °C, with an LTPD of 1.3. 2 Offset voltage drift is the average of the −40°C to +25°C delta and the +25°C to +125°C delta. Rev. D | Page 5 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION DRIVING CAPACITIVE LOADS INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL—OP193 OUTPUT PHASE REVERSAL—OP293 BATTERY-POWERED APPLICATIONS A MICROPOWER FALSE-GROUND GENERATOR A BATTERY-POWERED VOLTAGE REFERENCE A SINGLE-SUPPLY CURRENT MONITOR A SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER A LOW POWER, TEMPERATURE TO 4 mA TO 20 mA TRANSMITTER A MICROPOWER VOLTAGE CONTROLLED OSCILLATOR OUTLINE DIMENSIONS ORDERING GUIDE
