Datasheet AD824 (Analog Devices) - 7
DescriptionSingle Supply, Rail-to-Rail Low Power, FET-Input Quad Op Amp
Pages / Page17 / 7 — AD824. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. …
RevisionE
File Format / SizePDF / 370 Kb
AD824. Data Sheet. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 4. Parameter1. Rating. Table 5. Thermal Resistance
AD824 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4 Parameter1 Rating Table 5 Thermal Resistance
AD824 Data Sheet ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 4. Parameter1 Rating Table 5. Thermal Resistance
Supply Voltage ±18 V
Package Type θ 1 JA θJC Unit
Input Voltage −VS − 0.2 V to +VS 14-Lead SOIC (R) 120 36 °C/W Differential Input Voltage ±30 V 1 Output Short Circuit Duration to GND Indefinite θJA is specified for the worst case conditions, that is, θJA is specified for device soldered in circuit board for SOIC package. Storage Temperature Range −65°C to +150°C Operating Temperature Range −40°C to +85°C Junction Temperature Range −65°C to +150°C
ESD CAUTION
Lead Temperature Range (Soldering 60 sec) 300°C 1 Absolute maximum ratings apply to packaged parts unless otherwise noted. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability.
VCC I5 I6 R1 R2 Q18 Q29 R9 Q21 Q27 Q4 Q6 C3 J1 J2 Q5 +IN Q19 Q20 Q7 R7 C4 R13 R15 Q22 Q23 C2 VOUT –IN Q24 Q25 Q8 C1 Q2 Q3 Q31 Q28 Q26 R12 R14 R17 I1 I2 I3 I4
002
VEE
00875- Figure 2. Simplified Schematic of 1/4 AD824 Rev. E | Page 6 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT CHARACTERISTICS OUTPUT CHARACTERISTICS APPLICATIONS INFORMATION SINGLE SUPPLY VOLTAGE-TO-FREQUENCY CONVERTER SINGLE SUPPLY PROGRAMMABLE GAIN INSTRUMENTATION AMPLIFIER 3 V, SINGLE SUPPLY STEREO HEADPHONE DRIVER LOW DROPOUT BIPOLAR BRIDGE DRIVER A 3.3 V/5 V PRECISION SAMPLE-AND-HOLD AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
