Datasheet OP191, OP291, OP491 (Analog Devices) - 6
DescriptionMicropower Single-Supply Rail-to-Rail Input/Output Op Amps
Pages / Page24 / 6 — OP191/OP291/OP491. Vs = ±5V. 100. RL = 2kΩ A. V = +1. INPUT. VIN = 20V …
RevisionE
File Format / SizePDF / 569 Kb
OP191/OP291/OP491. Vs = ±5V. 100. RL = 2kΩ A. V = +1. INPUT. VIN = 20V p-p. OUTPUT. 200μs
OP191/OP291/OP491 Vs = ±5V 100 RL = 2kΩ A V = +1 INPUT VIN = 20V p-p OUTPUT 200μs
OP191/OP291/OP491 5V Vs = ±5V 100 RL = 2kΩ A 90 V = +1 INPUT VIN = 20V p-p OUTPUT 10 0% 5V 200μs
6 -00 294 00 Figure 6. Input and Output with Inputs Overdriven by 5 V Rev. E | Page 6 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT OVERVOLTAGE PROTECTION OUTPUT VOLTAGE PHASE REVERSAL OVERDRIVE RECOVERY APPLICATIONS INFORMATION SINGLE 3 V SUPPLY, INSTRUMENTATION AMPLIFIER SINGLE-SUPPLY RTD AMPLIFIER A 2.5 V REFERENCE FROM A 3 V SUPPLY 5 V ONLY, 12-BIT DAC SWINGS RAIL-TO-RAIL A HIGH-SIDE CURRENT MONITOR A 3 V, COLD JUNCTION COMPENSATED THERMOCOUPLE AMPLIFIER SINGLE-SUPPLY, DIRECT ACCESS ARRANGEMENT FOR MODEMS 3 V, 50 HZ/60 HZ ACTIVE NOTCH FILTER WITH FALSE GROUND SINGLE-SUPPLY, HALF-WAVE, AND FULL-WAVE RECTIFIERS OUTLINE DIMENSIONS ORDERING GUIDE
