Datasheet OP292, OP492 (Analog Devices) - 4
DescriptionDual/Quad Single-Supply Operational Amplifiers
Pages / Page20 / 4 — OP292/OP492. Data Sheet. Parameter. Symbol. Conditions. Min. Typ. Max. …
RevisionD
File Format / SizePDF / 345 Kb
OP292/OP492. Data Sheet. Parameter. Symbol. Conditions. Min. Typ. Max. Unit
OP292/OP492 Data Sheet Parameter Symbol Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ 3 V/µs −40°C ≤ TA ≤ +125°C 1 2 V/µs Gain Bandwidth Product GBP 4 MHz Phase Margin φm 75 Degrees Channel Separation CS fO = 1 kHz 100 dB NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 25 µV p-p Voltage Noise Density en f = 1 kHz 15 nV/√Hz Current Noise Density in 0.7 pA/√Hz 1 Long-term offset voltage drift is guaranteed by 1,000 hours life test performed on three independent wafer lots at 125°C with LTPD of 1.3. Rev. D | Page 4 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PHASE REVERSAL POWER SUPPLY CONSIDERATIONS TYPICAL APPLICATIONS DIRECT ACCESS ARRANGEMENT FOR TELEPHONE LINE INTERFACE SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER DAC OUTPUT AMPLIFIER 50 Hz/60 Hz SINGLE-SUPPLY NOTCH FILTER FOUR-POLE BESSEL LOW-PASS FILTER LOW COST, LINEARIZED THERMISTOR AMPLIFIER SINGLE-SUPPLY ULTRASONIC CLAMPING/LIMITING RECEIVER AMPLIFIER PRECISION SINGLE-SUPPLY VOLTAGE COMPARATOR PROGRAMMABLE PRECISION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
