Datasheet OP292, OP492 (Analog Devices) - 8 Manufacturer Analog Devices Description Dual/Quad Single-Supply Operational Amplifiers Pages / Page 20 / 8 — OP292/OP492. Data Sheet. 240. 200. S = ±15V. S = 5V. 210. 175. CM = 0V. … Revision D File Format / Size PDF / 345 Kb Document Language English
OP292/OP492. Data Sheet. 240. 200. S = ±15V. S = 5V. 210. 175. CM = 0V. –40°C ≤ T. A ≤ +125°C. 600 OP AMPS. 180. 150. 125. S T. 120. 100. UNI. TCVOS (µV/°C)
Model Line for this Datasheet Text Version of Document OP292/OP492 Data Sheet 240 200 V V S = ±15V S = 5V 210 V V 175 CM = 0V CM = 0V –40°C ≤ T –40°C ≤ T A ≤ +125°C A ≤ +125°C 600 OP AMPS 180 600 OP AMPS 150 150 125 S T S T 120 100 UNI UNI 90 75 60 50 30 25 0 0 0 1 2 3 4 5 6 7 8 0090 1 2 3 4 5 6 7 8 012TCVOS (µV/°C) TCV 00310-OS (µV/°C) 00310- Figure 9. OP292 Temperature Drift (TCVOS) Distribution @ ±15 V Figure 12. OP492 Temperature Drift (TCVOS) Distribution @ ±15 V600 900 V V S = 5V S = 5V 800 V 500 V O = 4V O = 4V RL = 10kΩ 700 V) V) m m 400 600 (V/ (V/ IN IN A A 500 300 P G P G O O 400 O O -L -L R 200 L = 10kΩ 300 PEN PEN RL = 2kΩ O O 200 RL = 2kΩ 100 100 0 0 –50 –25 0 25 50 75 100 125 010–50 –25 0 25 50 75 100 125 013TEMPERATURE (°C) TEMPERATURE (°C) 00310- 00310- Figure 10. OP292 Open-Loop Gain vs. Temperature @ 5 V Figure 13. OP492 Open-Loop Gain vs. Temperature @ 5 V250 400 VS = ±15V VS = ±15V V 350 O = ±10V VO = ±10V 200 300 V) V) RL = 10kΩ m m (V/ (V/ 250 IN 150 IN A A 200 P G P G O RL = 10kΩ O O O 100 -L -L 150 PEN PEN R O RL = 2kΩ O 100 L = 2kΩ 50 50 0 0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 014 011TEMPERATURE (°C) TEMPERATURE (°C) 00310- 00310- Figure 11. OP292 Open-Loop Gain vs. Temperature @ ±15 V Figure 14. OP492 Open-Loop Gain vs. Temperature @ ±15 V Rev. D | Page 8 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PHASE REVERSAL POWER SUPPLY CONSIDERATIONS TYPICAL APPLICATIONS DIRECT ACCESS ARRANGEMENT FOR TELEPHONE LINE INTERFACE SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER DAC OUTPUT AMPLIFIER 50 Hz/60 Hz SINGLE-SUPPLY NOTCH FILTER FOUR-POLE BESSEL LOW-PASS FILTER LOW COST, LINEARIZED THERMISTOR AMPLIFIER SINGLE-SUPPLY ULTRASONIC CLAMPING/LIMITING RECEIVER AMPLIFIER PRECISION SINGLE-SUPPLY VOLTAGE COMPARATOR PROGRAMMABLE PRECISION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
