Datasheet OP292, OP492 (Analog Devices) - 9
DescriptionDual/Quad Single-Supply Operational Amplifiers
Pages / Page20 / 9 — Data Sheet. OP292/OP492. 1.4. mA). 1.2. R (. S = ±15V. 1.0. VS = ±15V. R …
RevisionD
File Format / SizePDF / 345 Kb
Data Sheet. OP292/OP492. 1.4. mA). 1.2. R (. S = ±15V. 1.0. VS = ±15V. R AM. 0.8. S = +5V. 0.6. VS = +5V. CURRE. 0.4. 0.2. –50. –25. 100. 125. TEMPERATURE (°C)
Data Sheet OP292/OP492 1.4 mA) 1.2 R ( S = ±15V 1.0 VS = ±15V R AM 0.8 S = +5V 0.6 VS = +5V CURRE 0.4 0.2 –50 –25 100 125 TEMPERATURE (°C)
Data Sheet OP292/OP492 1.4 1.4 mA) 1.2 mA) 1.2 R ( V R ( IE S = ±15V IE IF IF L 1.0 L P 1.0 P VS = ±15V R AM R AM E E 0.8 V 0.8 P S = +5V P NT NT 0.6 0.6 VS = +5V CURRE CURRE Y Y L L P 0.4 P 0.4 UP UP S S 0.2 0.2 –50 –25 0 25 50 75 100 125
015
018
TEMPERATURE (°C) TEMPERATURE (°C)
00310- 00310- Figure 15. OP292 Supply Current per Amplifier vs. Temperature Figure 18. OP492 Supply Current per Amplifier vs. Temperature
6 6 VS = ±15V +SR VS = ±15V VO = ±10V VO = ±10V 5 5 +SR ) s 4 –SR ) s 4 µ µ –SR E (V/ E (V/ T +SR 3 T A 3 A +SR R R EW EW 2 SL 2 SL –SR –SR 1 1 VS = 5V VS = 5V VO = 0.1V, 4V VO = 0.1V, 4V 0 0 –50 –25 0 25 50 75 100 125
016
019
00310- 00310- Figure 16. OP292 Slew Rate vs. Temperature Figure 19. OP492 Slew Rate vs. Temperature
90 90 T T 80 A = 25°C A = 25°C 80 V+ = 5V VS = 10kΩ V– = 0V 70 R 70 L = 10kΩ RL = 10kΩ 60 60 GAIN GAIN 50 50 B) B) d d 40 N ( N ( 40 AI PHASE AI PHASE G 30 G MARGIN 135 30 MARGIN +135 PHASE = 83° PHASE = 92° EES) 20 90 20 +90 rees) R EG 10 45 Deg +45 10 ( E SE (D 0 0 0 0 A HAS P PH –10 –45 –45 –10 1k 10k 100k 1M 10M
017
1k 10k 100k 1M 10M
020
FREQUENCY (Hz)
00310-
FREQUENCY (Hz)
00310- Figure 17. OP292/OP492 Open-Loop Gain and Phase vs. Frequency @ 5 V Figure 20. OP292/OP492 Open-Loop Gain and Phase vs. Frequency @ ±15 V Rev. D | Page 9 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION PHASE REVERSAL POWER SUPPLY CONSIDERATIONS TYPICAL APPLICATIONS DIRECT ACCESS ARRANGEMENT FOR TELEPHONE LINE INTERFACE SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER DAC OUTPUT AMPLIFIER 50 Hz/60 Hz SINGLE-SUPPLY NOTCH FILTER FOUR-POLE BESSEL LOW-PASS FILTER LOW COST, LINEARIZED THERMISTOR AMPLIFIER SINGLE-SUPPLY ULTRASONIC CLAMPING/LIMITING RECEIVER AMPLIFIER PRECISION SINGLE-SUPPLY VOLTAGE COMPARATOR PROGRAMMABLE PRECISION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
