Datasheet AD813 (Analog Devices) - 5
DescriptionSingle Supply, Low Power Triple Video Amplifier
Pages / Page20 / 5 — AD813–SPECIFICATIONS Single Supply (@ TA = +25. C, RL = 150. , unless …
File Format / SizePDF / 594 Kb
AD813–SPECIFICATIONS Single Supply (@ TA = +25. C, RL = 150. , unless otherwise noted). Model. AD813A. Conditions. Min. Typ. Max. Units
AD813–SPECIFICATIONS Single Supply (@ TA = +25 C, RL = 150 , unless otherwise noted) Model AD813A Conditions Min Typ Max Units
8
C, RL = 150
V
, unless otherwise noted) Model AD813A Conditions V Min Typ Max Units S
DYNAMIC PERFORMANCE –3 dB Bandwidth G = +2, No Peaking +5 V 35 50 MHz +3 V 25 40 MHz Bandwidth for 0.1 dB Flatness G = +2 +5 V 12 20 MHz +3 V 8 15 MHz Slew Rate1 G = +2, R = 1 kΩ +5 V 100 V/µs L +3 V 50 V/µs NOISE/HARMONIC PERFORMANCE Input Voltage Noise f = 10 kHz +5 V, +3 V 3.5 nV√Hz Input Current Noise f = 10 kHz, +In +5 V, +3 V 1.5 pA√Hz –In +5 V, +3 V 18 pA√Hz Differential Gain Error2 NTSC, G = +2, R = 150 Ω +5 V 0.05 % L G = +1 +3 V 0.2 % Differential Phase Error2 G = +2 +5 V 0.05 Degrees G = +1 +3 V 0.2 Degrees DC PERFORMANCE Input Offset Voltage +5 V, +3 V 1.5 5 mV T –T 10 mV MIN MAX Offset Drift +5 V, +3 V 7 µV/°C –Input Bias Current +5 V, +3 V 7 30 µA T –T 40 µA MIN MAX +Input Bias Current +5 V, +3 V 0.5 1.7 µA T –T 2.5 µA MIN MAX Open-Loop Voltage Gain V = +2.5 V p-p +5 V 65 70 dB O V = +0.7 V p-p +3 V 69 dB O Open-Loop Transresistance V = +3 V p-p +5 V 180 300 kΩ O V = +1 V p-p +3 V 225 kΩ O INPUT CHARACTERISTICS Input Resistance +Input +5 V, +3 V 15 MΩ –Input +5 V 90 Ω Input Capacitance +Input 2 pF Input Common Mode +5 V 1.0 4.0 V Voltage Range +3 V 1.0 2.0 V Common-Mode Rejection Ratio Input Offset Voltage V = 1.25 V to 3.75 V +5 V 54 58 dB CM –Input Current 3 6.5 µA/V +Input Current 0.1 0.2 µA/V Input Offset Voltage V = 1 V to 2 V +3 V 56 dB CM –Input Current 3.5 µA/V +Input Current 0.1 µA/V OUTPUT CHARACTERISTICS Output Voltage Swing p-p R = 150 Ω, T –T +5 V 3.0 3.2 ±V p-p L MIN MAX +3 V 1.0 1.3 ±V p-p Output Current +5 V 20 30 mA +3 V 15 25 mA Short Circuit Current G = +2, R = 715 Ω +5 V 40 mA F V = 1 V IN –4– REV. B
