16 /7 — OP295/OP495. 500. BASED ON 1200 OP AMPS. VS = 5V. 450. TA = 25°C. SOURCE. …
Revision
G
PDF / 379 Kb
OP295/OP495. 500. BASED ON 1200 OP AMPS. VS = 5V. 450. TA = 25°C. SOURCE. 400. SINK. 350. S = ±15V. 300. T 250. UNI. CURR. 200. T U 15. 150. UT O. S = +5V. 100
OP295/OP49550040BASED ON 1200 OP AMPSVS = 5V450TA = 25°CSOURCE3540030SINK350A)VmS = ±15V(30025NTSOURCESET 25020UNICURRSINK200T U 15P150UT OV10S = +5V10050500–100–50050100150200250300 11 0 1- –50–250255075100 13 0 INPUT OFFSET VOLTAGE (µV) 33 1- 00 TEMPERATURE (°C) 33 00 Figure 11. OP495 Input Offset (VOS) Distribution Figure 14. Output Current vs. Temperature 500100BASED ON 1200 OP AMPSVS = 5VVS = ±15V450–40°C ≤ TA ≤ +85°CVO = ±10V400) V350/µ (V300INSRL = 100kΩTGA25010PUNIOO200-L N E150ROPL = 10kΩ10050RL = 2kΩ0100.40.81.21.62.02.42.83.2 14 12 –50–250255075100 0 -0 1- 31 TCVOS (µV/°C) 33 TEMPERATURE (°C) 03 0 00 Figure 12. OP495 TCVOS Distribution Figure 15. Open-Loop Gain vs. Temperature 2012VS = 5VVS = 5VVO = 4V1016A))(n/µV V8NT(12INRL = 100kΩURREGAC6ASRL = 10kΩ8OOPBI-L NUTE4INPOPR4L = 2kΩ20 33 0 0 5 1- –50–250255075100–50–250255075100 01 33 1- TEMPERATURE (°C) 00 TEMPERATURE (°C) 33 00 Figure 13. Input Bias Current vs. Temperature Figure 16. Open-Loop Gain vs. Temperature Rev. G | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS RAIL-TO-RAIL APPLICATION INFORMATION LOW DROP-OUT REFERENCE LOW NOISE, SINGLE-SUPPLY PREAMPLIFIER DRIVING HEAVY LOADS DIRECT ACCESS ARRANGEMENT SINGLE-SUPPLY INSTRUMENTATION AMPLIFIER SINGLE-SUPPLY RTD THERMOMETER AMPLIFIER COLD JUNCTION COMPENSATED, BATTERY-POWERED THERMOCOUPLE AMPLIFIER 5 V ONLY, 12-BIT DAC THAT SWINGS 0 V TO 4.095 V 4 mA TO 20 mA CURRENT-LOOP TRANSMITTER 3 V LOW DROPOUT LINEAR VOLTAGE REGULATOR LOW DROPOUT, 500 mA VOLTAGE REGULATOR WITH FOLDBACK CURRENT LIMITING SQUARE WAVE OSCILLATOR SINGLE-SUPPLY DIFFERENTIAL SPEAKER DRIVER HIGH ACCURACY, SINGLE-SUPPLY, LOW POWER COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
