Datasheet SSM2135 (Analog Devices) - 8
DescriptionDual Single-Supply Audio Operational Amplifier
Pages / Page17 / 8 — SSM2135. VS = 5V. 40 TA = 25°C. TA = 25°C. V = +100. L = 10kΩ. ) B. B) d. …
RevisionG
File Format / SizePDF / 328 Kb
SSM2135. VS = 5V. 40 TA = 25°C. TA = 25°C. V = +100. L = 10kΩ. ) B. B) d. –20. AV = +10. K (. –40. T S. –60. D E. CRO. –80. V = +1. –100. –105. –10. –120. –140. 100
SSM2135 VS = 5V 40 TA = 25°C TA = 25°C V = +100 L = 10kΩ ) B B) d –20 AV = +10 K ( –40 T S –60 D E CRO –80 V = +1 –100 –105 –10 –120 –140 100
SSM2135 60 50 VS = 5V VS = 5V 40 TA = 25°C TA = 25°C A R V = +100 L = 10kΩ 40 20 ) B 0 d 30 ( B) d IN –20 AV = +10 K ( GA 20 P AL –40 T S OO S -L 10 –60 D E CRO A –80 OS V = +1 L 0 C –100 –105 –10 –120 –140 –20 10 100 1k 10k 100k 1M 10M
15 18 0
1k 10k 100k 1M 10M
0 9- 9-
FREQUENCY (Hz)
34
FREQUENCY (Hz)
34 00 00 Figure 15. Crosstalk vs. Frequency Figure 18. Closed-Loop Gain vs. Frequency
140 100 VS = 5V VS = 5V TA = 25°C TA = 25°C 120 ) B 80 0 d ( 100 ) ION B T d 60 45 C ( IN GAIN es) JE 80 re E GA eg R D E 40 90 ( PHASE 60 E OD OOP -L -M N HAS E 20 135 P ON P 40 M O OM C 20 0 180 0 –20 225 100 1k 10k 100k 1M
16 0
1k 10k 100k 1M 10M
19 0 9- 9-
FREQUENCY (Hz)
34
FREQUENCY (Hz)
34 00 00 Figure 16. Common-Mode Rejection vs. Frequency Figure 19. Open-Loop Gain and Phase vs. Frequency
140 50 VS = 5V VS = 5V AV = +1 R 120 45 L= 2kΩ TA = 25°C VIN = 100mV p-p 40 TA = 25°C 100 AV = +1 35 ) 80 % ( B) 30 T d +PSRR O NEGATIVE EDGE R ( 60 O 25 R S SH –PSRR P 40 20 VER O POSITIVE EDGE 15 20 10 0 5 –20 0
0
17 0
0 100 200 300 400 500
02 9- 9-
FREQUENCY (Hz)
34
LOAD CAPACITANCE (pF)
34 00 00 Figure 17. Power Supply Rejection Ratio vs. Frequency Figure 20. Small Signal Overshoot vs. Load Capacitance Rev. G | Page 7 of 16 Document Outline FEATURES APPLICATIONS PIN CONNECTIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION APPLICATION CIRCUITS Low Noise Stereo Headphone Driver Amplifier Low Noise Microphone Preamplifier Single Supply Differential Line Driver Single-Supply Differential Line Receiver Pseudoreference Voltage Generator Digital Volume Control Circuit Logarithmic Volume Control Circuit OUTLINE DIMENSIONS ORDERING GUIDE
