Datasheet OP467 (Analog Devices)
DescriptionQuad Precision, High Speed Operational Amplifier
Pages / Page21 / 1 — Quad Precision, High. Speed Operational Amplifier. OP467. FEATURES. PIN …
RevisionI
File Format / SizePDF / 537 Kb
Quad Precision, High. Speed Operational Amplifier. OP467. FEATURES. PIN CONFIGURATIONS. High slew rate: 170 V/μs. OUT A 1. 14 OUT D
Datasheet OP467 Analog Devices, Revision: I
Quad Precision, High Speed Operational Amplifier OP467 FEATURES PIN CONFIGURATIONS High slew rate: 170 V/μs OUT A 1 14 OUT D Wide bandwidth: 28 MHz –IN A 2 13 –IN D + + Fast settling time: <200 ns to 0.01% +IN A 3 12 +IN D Low offset voltage: <500 μV V+ 4 OP467 11 V– Unity-gain stable +IN B 5 10 +IN C + + Low voltage operation: ±5 V to ±15 V –IN B 6 9 –IN C OUT B
01
7 8 OUT C
0
Low supply current: <10 mA
2- 30 00
Drives capacitive loads
Figure 1. 14-Lead CERDIP (Y Suffix) and 14-Lead PDIP (P Suffix)
APPLICATIONS A D A T T N N D –I OU NC OU –I High speed image display drivers 3 2 1 20 19 High frequency active filters +IN A 4 18 +IN D Fast instrumentation amplifiers OUT A 1 16 OUT D NC 5 17 NC High speed detectors –IN A 2 15 –IN D OP467 V+ 6 16 V– +IN A 3 14 +IN D (TOP VIEW) Integrators NC 7 15 NC V+ 4 OP467 13 V– Photo diode preamps +IN B 8 14 +IN C +IN B 5 12 +IN C
03 0 2- 30
GENERAL DESCRIPTION –IN B 6 11 –IN C
00
9 10 11 12 13 OUT B 7 10 OUT C
02 The OP467 is a quad, high speed, precision operational
NC
0
N B T C NC T B 8 9 NC N C
2-
–I –I
30
OU OU
amplifier. It offers the performance of a high speed op amp 00
NC = NO CONNECT NC = NO CONNECT
combined with the advantages of a precision op amp in a single Figure 2. 16-Lead SOIC (S Suffix) Figure 3. 20-Terminal LCC (RC Suffix) package. The OP467 is an ideal choice for applications where, traditionally, more than one op amp was used to achieve this
V+
level of speed and precision. The internal compensation of the OP467 ensures stable unity- gain operation, and it can drive large capacitive loads without oscillation. With a gain bandwidth product of 28 MHz driving a 30 pF load, output slew rate is 170 V/μs, and settling time to 0.01% in less than 200 ns, the OP467 provides excellent
+IN OUT
dynamic accuracy in high speed data acquisition systems. The
–IN
channel-to-channel separation is typically 60 dB at 10 MHz. The dc performance of the OP467 includes less than 0.5 mV of offset, a voltage noise density below 6 nV/√Hz, and a total supply current under 10 mA. The common-mode rejection ratio (CMRR) is typically 85 dB. The power supply rejection 004
V–
02- ratio (PSRR) is typically 107 dB. PSRR is maintained to better than 003 40 dB with input frequencies as high as 1 MHz. The low offset and Figure 4. Simplified Schematic drift plus high speed and low noise make the OP467 usable in applications such as high speed detectors and instrumentation. The OP467 is specified for operation from ±5 V to ±15 V over the extended industrial temperature range (−40°C to +85°C) and is available in a 14-lead PDIP, a 14-lead CERDIP, a 16-lead SOIC, and a 20-terminal LCC. Contact your local sales office for the MIL-STD-883 data sheet and availability.
Rev. * Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©3–20 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE DICE CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT SHORT-CIRCUIT PERFORMANCE UNUSED AMPLIFIERS PCB LAYOUT CONSIDERATIONS GROUNDING POWER SUPPLY CONSIDERATIONS SIGNAL CONSIDERATIONS PHASE REVERSAL SATURATION RECOVERY TIME HIGH SPEED INSTRUMENTATION AMPLIFIER 2 MHz BIQUAD BAND-PASS FILTER FAST I-TO-V CONVERTER OP467 SPICE MARCO-MODEL OUTLINE DIMENSIONS ORDERING GUIDE
