Datasheet OP467 (Analog Devices) - 2
DescriptionQuad Precision, High Speed Operational Amplifier
Pages / Page21 / 2 — OP467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionI
File Format / SizePDF / 537 Kb
OP467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Tutorials
OP467* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Tutorials
View a parametric search of comparable parts.
Tutorials
• MT-032: Ideal Voltage Feedback (VFB) Op Amp
DOCUMENTATION
• MT-033: Voltage Feedback Op Amp Gain and Bandwidth
Application Notes
• MT-047: Op Amp Noise • AN-402: Replacing Output Clamping Op Amps with Input • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS Clamping Amps Noise, and Equivalent Noise Bandwidth • AN-414: Low Cost, Low Power Devices for HDSL • MT-049: Op Amp Total Output Noise Calculations for Applications Single-Pole System • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease • MT-050: Op Amp Total Output Noise Calculations for Design Constraints in Low Voltage High Speed Systems Second-Order System • AN-581: Biasing and Decoupling Op Amps in Single • MT-052: Op Amp Noise Figure: Don't Be Misled Supply Applications • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD,
Data Sheet
SFDR, MTPR • OP467: Military Data Sheet • MT-056: High Speed Voltage Feedback Op Amps • OP467: Quad Precision, High Speed Operational Amplifier • MT-058: Effects of Feedback Capacitance on VFB and CFB Data Sheet Op Amps • MT-059: Compensating for the Effects of Input
TOOLS AND SIMULATIONS
Capacitance on VFB and CFB Op Amps Used in Current-to- • Analog Filter Wizard Voltage Converters • Analog Photodiode Wizard • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps • Power Dissipation vs Die Temp • VRMS/dBm/dBu/dBV calculators
DESIGN RESOURCES
• OP467 SPICE Macro-Model • OP467 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all OP467 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE DICE CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION OUTPUT SHORT-CIRCUIT PERFORMANCE UNUSED AMPLIFIERS PCB LAYOUT CONSIDERATIONS GROUNDING POWER SUPPLY CONSIDERATIONS SIGNAL CONSIDERATIONS PHASE REVERSAL SATURATION RECOVERY TIME HIGH SPEED INSTRUMENTATION AMPLIFIER 2 MHz BIQUAD BAND-PASS FILTER FAST I-TO-V CONVERTER OP467 SPICE MARCO-MODEL OUTLINE DIMENSIONS ORDERING GUIDE
