Datasheet AD827 (Analog Devices) - 2
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page13 / 2 — AD827* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 248 Kb
AD827* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD827* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
AD827
View a parametric search of comparable parts.
Product Selection Guide
• High Speed Amplifiers Selection Table
DOCUMENTATION Tutorials Application Notes
• MT-032: Ideal Voltage Feedback (VFB) Op Amp • AN-402: Replacing Output Clamping Op Amps with Input • MT-047: Op Amp Noise Clamping Amps • MT-048: Op Amp Noise Relationships: 1/f Noise, RMS • AN-417: Fast Rail-to-Rail Operational Amplifiers Ease Noise, and Equivalent Noise Bandwidth Design Constraints in Low Voltage High Speed Systems • MT-049: Op Amp Total Output Noise Calculations for • AN-581: Biasing and Decoupling Op Amps in Single Single-Pole System Supply Applications • MT-050: Op Amp Total Output Noise Calculations for
Data Sheet
Second-Order System • AD827: High Speed, Low Power Dual Op Amp Data Sheet • MT-052: Op Amp Noise Figure: Don't Be Misled • AD827: Military Data Sheet • MT-053: Op Amp Distortion: HD, THD, THD + N, IMD, SFDR, MTPR
TOOLS AND SIMULATIONS
• MT-056: High Speed Voltage Feedback Op Amps • Analog Filter Wizard • MT-058: Effects of Feedback Capacitance on VFB and CFB • Analog Photodiode Wizard Op Amps • Power Dissipation vs Die Temp • MT-060: Choosing Between Voltage Feedback and Current Feedback Op Amps • VRMS/dBm/dBu/dBV calculators • AD827 SPICE Macro Model
DESIGN RESOURCES
• AD827 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD827 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES CONNECTION DIAGRAMS PRODUCT DESCRIPTION APPLICATION HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALLIZATION PHOTOGRAPH Typical Performance Characteristics INPUT PROTECTION PRECAUTIONS VIDEO LINE DRIVER A HIGH SPEED THREE OP AMP INSTRUMENTATION AMPLIFIER CIRCUIT A TWO-CHIP VOLTAGE-CONTROLLED AMPLIFIER (VCA) WITH EXPONENTIAL RESPONSE Guidelines for Grounding and Bypassing OUTLINE DIMENSIONS Revision History
