Datasheet AD827 (Analog Devices) - 3
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page13 / 3 — AD827–SPECIFICATIONS (@ TA = +25. C, unless otherwise noted.). AD827J. …
RevisionC
File Format / SizePDF / 248 Kb
AD827–SPECIFICATIONS (@ TA = +25. C, unless otherwise noted.). AD827J. AD827A/S. Model. Conditions. Min. Typ. Max. Unit
AD827–SPECIFICATIONS (@ TA = +25 C, unless otherwise noted.) AD827J AD827A/S Model Conditions Min Typ Max Unit
AD827
C, unless otherwise noted.) AD827J AD827A/S Model Conditions VS Min Typ Max Min Typ Max Unit
DC PERFORMANCE Input Offset Voltage1 ±5 V 0.5 2 0.3 2 mV TMIN to TMAX 3.5 4 mV ±15 V 4 4 mV TMIN to TMAX 6 6 mV Offset Voltage Drift ±5 V to ±15 V 15 15 µV/°C Input Bias Current ±5 V to ±15 V 3.3 7 3.3 7 µA TMIN to TMAX 8.2 9.5 µA Input Offset Current ±5 V to ±15 V 50 300 50 300 nA TMIN to TMAX 400 400 nA Offset Current Drift ±5 V to ±15 V 0.5 0.5 nA/°C Common-Mode Rejection Ratio VCM = ± 2.5 V ±5 V 78 95 80 95 dB VCM = ± 12 V ±15 V 78 95 80 95 dB T ± MIN to TMAX 5 V to ± 15 V 75 75 dB Power Supply Rejection Ratio ±5 V to ±15 V 75 86 75 86 dB TMIN to TMAX 72 72 dB Open-Loop Gain VO = ± 2.5 V ±5 V RLOAD = 500 Ω 2 3.5 2 3.5 V/mV TMIN to TMAX 1 1 V/mV RLOAD = 150 Ω 1.6 1.6 V/mV VOUT = ± 10 V ±15 V RLOAD = 1 kΩ 3 5.5 3 5.5 V/mV TMIN to TMAX 1.5 1.5 V/mV MATCHING CHARACTERISTICS Input Offset Voltage ±5 V 0.4 0.2 mV Crosstalk f = 5 MHz ±5 V 85 85 dB DYNAMIC PERFORMANCE Unity-Gain Bandwidth ±5 V 35 35 MHz ±15 V 50 50 MHz Full Power Bandwidth2 VO = 5 V p-p, RLOAD = 500 Ω ± 5 V 12.7 12.7 MHz VO = 20 V p-p, RLOAD = 1 kΩ ±15 V 4.7 4.7 MHz Slew Rate3 RLOAD = 500 Ω ±5 V 200 200 V/µs RLOAD = 1 kΩ ±15 V 300 300 V/µs Settling Time to 0.1% AV = –1 –2.5 V to +2.5 V ±5 V 65 65 ns –5 V to +5 V ±15 V 120 120 ns Phase Margin CLOAD = 10 pF ±15 V RLOAD = 1 kΩ 50 50 Degrees Differential Gain Error f = 4.4 MHz ±15 V 0.04 0.04 % Differential Phase Error f = 4.4 MHz ±15 V 0.19 0.19 Degrees Input Voltage Noise f = 10 kHz ±15 V 15 15 nV/√Hz Input Current Noise f = 10 kHz ±15 V 1.5 1.5 pA/√Hz Input Common-Mode Voltage Range ±5 V +4.3 +4.3 V –3.4 –3.4 V ±15 V +14.3 +14.3 V –13.4 –13.4 V Output Voltage Swing RLOAD = 500 Ω ±5 V 3.0 3.6 3.0 3.6 ±V RLOAD = 150 Ω ±5 V 2.5 3.0 2.5 3.0 ±V RLOAD = 1 kΩ ±15 V 12 13.3 12 13.3 ±V RLOAD = 500 Ω ±15 V 10 12.2 10 12.2 ±V Short-Circuit Current Limit ±5 V to ±15 V 32 32 mA INPUT CHARACTERISTICS Input Resistance 300 300 kΩ Input Capacitance 1.5 1.5 pF –2– REV. C Document Outline FEATURES CONNECTION DIAGRAMS PRODUCT DESCRIPTION APPLICATION HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALLIZATION PHOTOGRAPH Typical Performance Characteristics INPUT PROTECTION PRECAUTIONS VIDEO LINE DRIVER A HIGH SPEED THREE OP AMP INSTRUMENTATION AMPLIFIER CIRCUIT A TWO-CHIP VOLTAGE-CONTROLLED AMPLIFIER (VCA) WITH EXPONENTIAL RESPONSE Guidelines for Grounding and Bypassing OUTLINE DIMENSIONS Revision History
