AD847Typical Characteristics (@ +25 8 C and VS = 6 15 V, unless otherwise noted)2020 ± Volts 1515+VIN+VOUT1010–VIN–VOUT55OUTPUT VOLTAGE SWING – VoltsR = 500LOAD Ω INPUT COMMON-MODE RANGE –000510152005101520SUPPLY VOLTAGE – ± VoltsSUPPLY VOLTAGE – ± Volts Figure 1. Input Common-Mode Range vs. Supply Voltage Figure 2. Output Voltage Swing vs. Supply Voltage 306255.520 ± 15 V SUPPLIES155104.5 ± QUIESCENT CURRENT – mA5V SUPPLIES5OUTPUT VOLTAGE SWING – Volts p-p04101001k10k05101520LOAD RESISTANCE – Ω SUPPLY VOLTAGE – ± Volts Figure 3. Output Voltage Swing vs. Load Resistance Figure 4. Quiescent Current vs. Supply Voltage 5100 µ A10 Ω 4V = ± 5VS13INPUT BIAS CURRENT –OUTPUT IMPEDANCE – 0.120.01–60–40–2002040608010012014010k100k1M10M100MTEMPERATURE – ° CFREQUENCY – Hz Figure 5. Input Bias Current vs. Temperature Figure 6. Output Impedance vs. Frequency REV. F –5–
