Datasheet LTC1407-1, LTC1407A-1 (Analog Devices) - 2
DescriptionSerial 12-Bit/14-Bit, 3Msps Simultaneous Sampling ADCs with Shutdown
Pages / Page26 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER …
File Format / SizePDF / 520 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Notes 1, 2). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Notes 1, 2) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC1407-1/LTC1407A-1
TOP VIEW Supply Voltage (VDD) ...4V CH0+ 1 10 CONV CH0– 2 9 SCK Analog Input Voltage (Note 3) ... –0.3V to (VDD + 0.3V) V 3 REF 11 8 SDO Digital Input Voltage .. –0.3V to (V CH1+ 4 7 VDD DD + 0.3V) CH1– 5 6 GND Digital Output Voltage ... –0.3V to (VDD + 0.3V) MSE PACKAGE Power Dissipation ...100mW 10-LEAD PLASTIC MSOP T Operation Temperature Range JMAX = 125°C, θJA = 40°C/W EXPOSED PAD IS GND (PIN 11), MUST BE SOLDERED TO PCB LTC1407C-1/LTC1407AC-1 .. 0°C to 70°C LTC1407I-1/LTC1407AI-1 ...–40°C to 85°C Storage Temperature Range ...–65°C to 150°C Lead Temperature (Soldering, 10 sec) .. 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC1407CMSE-1#PBF LTC1407CMSE-1#TRPBF LTBGT 10-Lead Plastic MSOP 0°C to 70°C LTC1407IMSE-1#PBF LTC1407IMSE-1#TRPBF LTBGV 10-Lead Plastic MSOP –40°C to 85°C LTC1407ACMSE-1#PBF LTC1407ACMSE-1#TRPBF LTBGW 10-Lead Plastic MSOP 0°C to 70°C LTC1407AIMSE-1#PBF LTC1407AIMSE-1#TRPBF LTBGX 10-Lead Plastic MSOP –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
CONVERTER CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = 3V. LTC1407-1 LTC1407A-1 PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX
Resolution (No Missing Codes) l 12 14 Bits Integral Linearity Error (Notes 5, 17) l –2 ±0.25 2 –4 ±0.5 4 LSB Offset Error (Notes 4, 17) l –10 ±1 10 –20 ±2 20 LSB Offset Match from CH0 to CH1 (Note 17) –5 ±0.5 5 –10 ±1 10 LSB Gain Error (Notes 4, 17) l –30 ±5 30 –60 ±10 60 LSB Gain Match from CH0 to CH1 (Note 17) –5 ±1 5 –10 ±2 10 LSB Gain Tempco Internal Reference (Note 4) ±15 ±15 ppm/°C External Reference ±1 ±1 ppm/°C 14071fb 2
