Datasheet LTC1407-1, LTC1407A-1 (Analog Devices) - 3
DescriptionSerial 12-Bit/14-Bit, 3Msps Simultaneous Sampling ADCs with Shutdown
Pages / Page26 / 3 — The. ANALOG INPUT. denotes the specifi cations which apply over the full …
File Format / SizePDF / 520 Kb
The. ANALOG INPUT. denotes the specifi cations which apply over the full operating temperature range,
The ANALOG INPUT denotes the specifi cations which apply over the full operating temperature range,
LTC1407-1/LTC1407A-1
The ANALOG INPUT
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = 3V. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Differential Input Range (Notes 3, 8, 9) 2.7V ≤ VDD ≤ 3.3V –1.25 to 1.25 V VCM Analog Common Mode + Differential 0 to VDD V Input Range (Note 10) IIN Analog Input Leakage Current l 1 μA CIN Analog Input Capacitance (Note 18) 13 pF tACQ Sample-and-Hold Acquisition Time (Note 6) l 39 ns tAP Sample-and-Hold Aperture Delay Time 1 ns tJITTER Sample-and-Hold Aperture Delay Time Jitter 0.3 ps tSK Sample-and-Hold Aperture Skew from CH0 to CH1 200 ps CMRR Analog Input Common Mode Rejection Ratio fIN = 1MHz, VIN = 0V to 3V –60 dB fIN = 100MHz, VIN = 0V to 3V –15 dB
DYNAMIC ACCURACY The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. With internal reference, VDD = 3V. Single-ended signal drive CH0+/CH1+ with CHO–/CH1– = 1.5V DC. Differential signals drive both inputs of each channel with VCM = 1.5V DC. LTC1407-1 LTC1407A-1 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
SINAD Signal-to-Noise Plus 100kHz Input Signal (Note 19) 70.5 73.5 dB Distortion Ratio 750kHz Input Signal (Note 19) l 68 70.5 70 73.5 dB 100kHz Input Signal, External VREF = 3.3V, 72.0 76.3 dB VDD ≥ 3.3V (Note 19) 750kHz Input Signal, External VREF = 3.3V, 72.0 76.3 dB VDD ≥ 3.3V (Note 19) THD Total Harmonic 100kHz First 5 Harmonics (Note 19) –87 –90 dB Distortion 750kHz First 5 Harmonics (Note 19) l –83 –77 –86 –80 dB SFDR Spurious Free 100kHz Input Signal (Note 19) 87 90 dB Dynamic Range 750kHz Input Signal (Note 19) 83 86 dB IMD Intermodulation 0.625VP-P 1.4MHz Summed with 0.625VP-P, 1.56MHz –82 –82 dB Distortion into CH0+ and Inverted into CHO–. Also Applicable to CH1+ and CH1– Code-to-Code VREF = 2.5V (Note 17) 0.25 1 LSBRMS Transition Noise Full Power Bandwidth VIN = 2.5VP-P, SDO = 11585LSBP-P (–3dBFS) (Note 15) 50 50 MHz Full Linear Bandwidth S/(N + D) ≥ 68dB 5 5 MHz 14071fb 3
