LTC1410 WWWUUWUABSOLUTEAXI UAR TI GSPACKAGE/ORDER I FOR ATIOAVDD = DVDD = VDD (Notes 1, 2) TOP VIEW ORDER Supply Voltage (VDD) .. 6V +A 1 28 IN AVDD PART NUMBER Negative Supply Voltage (VSS) ... –6V –A 2 27 IN DVDD Total Supply Voltage (VDD to VSS) .. 12V V 3 26 REF VSS LTC1410CG Analog Input Voltage REFCOMP 4 25 BUSY LTC1410CSW (Note 3) .. VSS – 0.3V to VDD + 0.3V AGND 5 24 CS LTC1410IG Digital Input Voltage (Note 4) .. VSS – 0.3V to 10V D11(MSB) 6 23 CONVST LTC1410ISW Digital Output Voltage ... – 0.3V to VDD + 0.3V D10 7 22 RD Power Dissipation ... 500mW D9 8 21 SHDN Operating Temperature Range D8 9 20 NAP/SLP LTC1410C .. 0°C to 70°C D7 10 19 OGND LTC1410I ... – 40°C to 85°C D6 11 18 D0 Storage Temperature Range .. – 65°C to 150°C D5 12 17 D1 Lead Temperature (Soldering, 10 sec)... 300°C D4 13 16 D2 DGND 14 15 D3 G PACKAGE SW PACKAGE 28-LEAD PLASTIC SSOP 28-LEAD PLASTIC SO WIDE TJMAX = 110°C, θJA = 90°C/W (SW) TJMAX = 110°C, θJA = 95°C/W (G) Consult factory for Military grade parts. UCO VERTER CHAR CA TERISTICS The ● denotes specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25 ° C. With Internal Reference (Notes 5, 6)PARAMETERCONDITIONSMINTYPMAXUNITS Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error (Note 7) ● ±0.3 ±1 LSB Differential Linearity Error ● ±0.3 ±1 LSB Offset Error (Note 8) ±2 ±6 LSB ● ±8 LSB Full-Scale Error ±15 LSB Full-Scale Tempco IOUT(REF) = 0 ● ±15 ppm/°C UUA ALOG I PUT The ● denotes specifications which apply over the full operating temperature range, otherwisespecifications are at TA = 25 ° C. (Note 5)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS VIN Analog Input Range (Note 9) 4.75V ≤ VDD ≤ 5.25V, – 5.25V ≤ VSS ≤ – 4.75V ● ±2.5 V IIN Analog Input Leakage Current CS = High ● ±1 µA CIN Analog Input Capacitance Between Conversions 17 pF During Conversions 5 pF t ACQ Sample-and-Hold Acquisition Time ● 50 100 ns t AP Sample-and-Hold Aperture Delay Time –1.5 ns tjitter Sample-and-Hold Aperture Delay Time Jitter 5 psRMS CMRR Analog Input Common Mode Rejection Ratio – 2.5V < (– AIN = AIN) < 2.5V 60 dB 2
