Datasheet LTC1420 (Analog Devices) - 2
Description12-Bit, 10Msps, Sampling ADC
Pages / Page20 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. 0VDD = VDD (Notes 1, …
File Format / SizePDF / 257 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. 0VDD = VDD (Notes 1, 2). CONVERTER CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO 0VDD = VDD (Notes 1, 2) CONVERTER CHARACTERISTICS The
LTC1420
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO 0VDD = VDD (Notes 1, 2)
TOP VIEW Supply Voltage (V ORDER PART DD) ... 6V +A 1 28 IN GAIN Negative Supply Voltage (V NUMBER SS) .. – 6V –A 2 27 IN OF Total Supply Voltage (V V 3 26 CLK DD to VSS) ... 12V CM LTC1420CGN SENSE 4 25 V Analog Input Voltage SS V 5 24 REF GND LTC1420IGN (Note 3) ... (VSS – 0.3V) to (VDD + 0.3V) GND 6 23 VDD Digital Input Voltage V 7 22 DD OVDD GND 8 21 OGND (Note 4) ... (VSS – 0.3V) to (VDD + 0.3V) D11 (MSB) 9 20 D0 Digital Output Voltage .. (VSS – 0.3V) to (VDD + 0.3V) D10 10 19 D1 Power Dissipation .. 500mW D9 11 18 D2 D8 12 17 D3 Operating Temperature Range D7 13 16 D4 LTC1420C ... 0°C to 70°C D6 14 15 D5 LTC1420I .. – 40°C to 85°C GN PACKAGE 28-LEAD PLASTIC SSOP Storage Temperature Range ... – 65°C to 150°C TJMAX = 125°C, θJA = 80°C/W Lead Temperature (Soldering, 10 sec).. 300°C Consult factory for Military grade parts.
U CONVERTER CHARACTERISTICS The
C. With Internal 4.096V Reference. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error (Note 7) ● ±0.35 ±1 LSB Differential Linearity Error ● ±0.25 ±1 LSB Offset Error (Note 8) ±5 12 LSB ● 16 LSB Full-Scale Error ±10 30 LSB Full-Scale Tempco IOUT(REF) = 0 ±15 ppm/°C
U U A ALOG I PUT The
C. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Input Range (Note 9) VREF = 4.096V (SENSE = 0V), GAIN = 5V (1×) ● ±2.048 V +AIN – (–AIN) VREF = 4.096V (SENSE = 0V), GAIN = 0V (2×) ● ±1.024 V VREF = 2.048V (SENSE = VREF), GAIN = 5V (1×) ● ±1.024 V VREF = 2.048V (SENSE = VREF), GAIN = 0V (2×) ● ±0.512 V External VREF (SENSE = 5V), GAIN = 5V (1×) ● ±VREF/2 V External VREF (SENSE = 5V), GAIN = 0V (2×) ● ±VREF/4 V IIN Analog Input Leakage Current ● ±20 µA CIN Analog Input Capacitance Between Conversions 12 pF During Conversions 6 pF tACQ Sample-and-Hold Acquisition Time 30 ns tAP Sample-and-Hold Aperture Delay Time – 250 ps tjitter Sample-and-Hold Aperture Delay Time Jitter 0.6 ps CMRR Analog Input Common Mode Rejection Ratio –2.048V < (–AIN = +AIN) < 2.048V 75 dB 1420fa 2
