Datasheet LTC1420 (Analog Devices) - 3
Description12-Bit, 10Msps, Sampling ADC
Pages / Page20 / 3 — DY A IC ACCURACY The. denotes the specifications which apply over the …
File Format / SizePDF / 257 Kb
DY A IC ACCURACY The. denotes the specifications which apply over the full operating temperature range,
DY A IC ACCURACY The denotes the specifications which apply over the full operating temperature range,
LTC1420
U W DY A IC ACCURACY The
C. VDD = 5V, VSS = –5V, fSAMPLE = 10MHz, VREF = 4.096V. + AIN = – 0.1dBFS single ended input, – AIN = 0V. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
S/(N + D) Signal-to-Noise Plus Distortion Ratio 1MHz Input Signal ● 68.5 71.4 dB 5MHz Input Signal ● 68 71.0 dB THD Total Harmonic Distortion 1MHz Input Signal, First 5 Harmonics ● – 84 – 77 dB 5MHz Input Signal, First 5 Harmonics ● – 81 – 73 dB SFDR Peak Harmonic or Spurious Noise 1MHz Input Signal ● – 85 – 78.5 dB 5MHz Input Signal ● – 83 – 75 dB IMD Intermodulation Distortion fIN1 = 29.37kHz, fIN2 = 32.446kHz – 80 dB Full-Power Bandwidth 100 MHz Input Referred Noise ±2.048V Input Range 0.22 LSBRMS ±1.024V Input Range, 2x Mode (SENSE = GAIN = 0V) 0.33 LSBRMS Overvoltage Recovery Time 1.5x FS Input to 0 (Settling to 1LSB) 15 ns Full-Scale Step Acquisition Time Settling to 1LSB 15 ns
U U U INTERNAL REFERENCE CHARACTERISTICS TA = 25
C. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
VCM Output Voltage IOUT = 0 2.475 2.50 2.525 V VCM Output Tempco IOUT = 0 ±15 ppm/°C VCM Line Regulation 4.75V ≤ VDD ≤ 5.25V 0.6 mV/V – 5.25V ≤ VSS ≤ –4.75V 0.03 mV/V VCM Output Resistance 0.1mA ≤ ⏐IOUT⏐ ≤ 0.1mA 8 Ω VREF Output Voltage SENSE = GND, IOUT = 0 4.096 V SENSE = VREF, IOUT = 0 2.048 V SENSE = VDD Drive VREF with V External Reference VREF Output Tempco ±15 ppm/°C
U U DIGITAL I PUTS A D DIGITAL OUTPUTS The
C. Specifications are guaranteed for both dual supply and single supply operation. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage (Clock Pin) VDD = 5.25V, VSS = 0V ● 2.4 V VDD = 5.25V, VSS = – 5V ● 3.5 V VIL Low Level Input Voltage (Clock Pin) VDD = 4.75V, VSS = 0V ● 0.8 V VDD = 4.75V, VSS = – 5V ● 1 V IIN Digital Input Current VIN = 0V to VDD ● ±10 µA CIN Digital Input Capacitance 1.8 pF VOH High Level Output Voltage 0VDD = 4.75V, IO = –10µA 4.74 V 0VDD = 4.75V, IO = –200µA ● 4.0 4.71 V 0VDD = 2.7V, IO = –10µA 2.6 V 0VDD = 2.7V, IO = –200µA ● 2.3 V VOL Low Level Output Voltage 0VDD = 4.75V, IO = 160µA 0.05 V 0VDD = 4.75V, IO = 1.6mA ● 0.10 0.4 V 0VDD = 2.7V, IO = 160µA 0.05 V 0VDD = 2.7V, IO = 1.6mA ● 0.10 0.4 V ISOURCE Output Source Current VOUT = 0V 50 mA ISINK Output Sink Current VOUT = VDD 35 mA 1420fa 3
