Datasheet LTC1594, LTC1598 (Analog Devices) - 4
Description8-Channel, Micropower Sampling 12-Bit Serial I/O A/D Converter
Pages / Page24 / 4 — AC CHARACTERISTICS The. denotes the specifications which apply over the …
File Format / SizePDF / 246 Kb
AC CHARACTERISTICS The. denotes the specifications which apply over the full operating temperature range,
AC CHARACTERISTICS The denotes the specifications which apply over the full operating temperature range,
LTC1594/LTC1598
C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tSMPL Analog Input Sample Time See Figure 1 in Applications Information 1.5 CLK Cycles fSMPL(MAX) Maximum Sampling Frequency See Figure 1 in Applications Information ● 16.8 kHz tCONV Conversion Time See Figure 1 in Applications Information 12 CLK Cycles tdDO Delay Time, CLK↓ to DOUT Data Valid See Test Circuits ● 250 600 ns tdis Delay Time, CS↑ to DOUT Hi-Z See Test Circuits ● 135 300 ns ten Delay Time, CLK↓ to DOUT Enabled See Test Circuits ● 75 200 ns thDO Time Output Data Remains Valid After CLK↓ CLOAD = 100pF 230 ns tf DOUT Fall Time See Test Circuits ● 50 150 ns tr DOUT Rise Time See Test Circuits ● 50 150 ns tON Enable Turn-On Time See Figure 1 in Applications Information ● 260 700 ns tOFF Enable Turn-Off Time See Figure 2 in Applications Information ● 100 300 ns tOPEN Break-Before-Make Interval ● 35 160 ns CIN Input Capacitance Analog Inputs On-Channel 20 pF Off-Channel 5 pF Digital Input 5 pF
Note 1:
Note 6:
Linearity error is specified between the actual end points of the may cause permanent damage to the device. Exposure to any Absolute A/D transfer curve. Maximum Rating condition for extended periods may affect device
Note 7:
Two on-chip diodes are tied to each reference and analog input reliability and lifetime. which will conduct for reference or analog input voltages one diode drop
Note 2:
All voltage values are with respect to GND. below GND or one diode drop above VCC. This spec allows 50mV forward
Note 3:
These devices are specified at 5V. Consult factory for 3V bias of either diode for 4.5V ≤ VCC ≤ 5.5V. This means that as long as the specified devices (LTC1594L/LTC1598L). reference or analog input does not exceed the supply voltage by more than
Note 4:
Increased leakage currents at elevated temperatures cause the S/H 50mV, the output code will be correct. To achieve an absolute 0V to 5V to droop, therefore it is recommended that f input voltage range, it will therefore require a minimum supply voltage of CLK ≥ 160kHz at 85°C, f 4.950V over initial tolerance, temperature variations and loading. CLK ≥ 75kHz at 70°C and fCLK ≥ 1kHz at 25°C.
Note 5:
V
Note 8:
Recommended operating condition. Not 100% production tested. CC = 5V, VREF = 5V and CLK = 320kHz unless otherwise specified. CSADC and CSMUX pins are tied together during the test.
Note 9:
Channel leakage current is measured after the channel selection.
W U TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Sample Rate Supply Current vs Temperature Reference Current vs Temperature
1000 450 95.0 TA = 25°C T VCC = VREF = 5V A = 25°C VCC = 5V V fSMPL = 16.8kHz CC = VREF = 5V V 94.5 REF = 5V f fCLK = 320kHz 400 CLK = 320kHz fCLK = 320kHz fSMPL = 16.8kHz μA) μA) μA) 100 94.0 350 93.5 300 10 93.0 SUPPLY CURRENT ( SUPPLY CURRENT ( REFERENCE CURRENT ( 250 92.5 1 200 92.0 0.1 1 10 100 – 55 – 35 –15 5 25 45 65 85 105 125 – 55 – 35 –15 5 25 45 65 85 105 125 SAMPLE FREQUENCY (kHz) TEMPERATURE (°C) TEMPERATURE (°C) 1594/98 G01 1594/98 G02 1594/98 G03 15948fb 4
