Datasheet LTC1594L, LTC1598L (Analog Devices) - 4
Description4- and 8-Channel, 3V Micropower Sampling 12-Bit Serial I/O A/D Converters
Pages / Page24 / 4 — AC CHARACTERISTICS The. denotes the specifications which apply over the …
File Format / SizePDF / 370 Kb
AC CHARACTERISTICS The. denotes the specifications which apply over the full operating temperature range,
AC CHARACTERISTICS The denotes the specifications which apply over the full operating temperature range,
LTC1594L/LTC1598L
C.(Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tSMPL Analog Input Sample Time See Figure 1 in Applications Information 1.5 CLK Cycles fSMPL(MAX) Maximum Sampling Frequency See Figure 1 in Applications Information ● 10.5 kHz tCONV Conversion Time See Figure 1 in Applications Information 12 CLK Cycles tdDO Delay Time, CLK↓ to DOUT Data Valid See Test Circuits ● 600 1500 ns tdis Delay Time, CS↑ to DOUT Hi-Z See Test Circuits ● 220 600 ns ten Delay Time, CLK↓ to DOUT Enabled See Test Circuits ● 180 500 ns thDO Time Output Data Remains Valid After CLK↓ CLOAD = 100pF 520 ns tf DOUT Fall Time See Test Circuits ● 60 180 ns tr DOUT Rise Time See Test Circuits ● 80 180 ns tON Enable Turn-On Time See Figure 1 in Applications Information ● 540 1200 ns tOFF Enable Turn-Off Time See Figure 2 in Applications Information ● 190 500 ns tOPEN Break-Before-Make Interval ● 125 350 ns CIN Input Capacitance Analog Inputs On-Channel 20 pF Off-Channel 5 pF Digital Input 5 pF
Note 1:
Note 7:
Two on-chip diodes are tied to each reference and analog input of a device may be impaired. which will conduct for reference or analog input voltages one diode drop
Note 2:
All voltage values are with respect to GND. below GND or one diode drop above VCC. This spec allows 50mV forward
Note 3:
These devices are specified at 3V. Consult factory for 5V bias of either diode for 2.7V ≤ VCC ≤ 3.6V. This means that as long as the specified devices (LTC1594/LTC1598). reference or analog input does not exceed the supply voltage by more than 50mV, the output code will be correct. To achieve an absolute 0V to 3V
Note 4:
Increased leakage currents at elevated temperatures cause the S/H input voltage range, it will therefore require a minimum supply voltage of to droop, therefore it is recommended that fCLK ≥ 200kHz at 85°C, 2.950V over initial tolerance, temperature variations and loading. fCLK ≥ 75kHz at 70°C and fCLK ≥ 1kHz at 25°C.
Note 8:
Recommended operating condition.
Note 5:
VCC = 2.7V, VREF = 2.5V and CLK = 200kHz unless otherwise specified. CSADC and CSMUX pins are tied together during the test.
Note 9:
Channel leakage current is measured after the channel selection.
Note 6:
Linearity error is specified between the actual end points of the A/D transfer curve.
W U TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Sample Rate Supply Current vs Temperature Reference Current vs Temperature
1000 260 53 TA = 25°C T V A = 25°C CC = 2.7V V 52 CC = 2.7V V V CC = 2.7V REF = 2.5V VREF = 2.5V f 220 VREF = 2.5V 51 CLK = 200kHz fCLK = 200kHz f f CLK = 200kHz µA) SMPL = 10.5kHz µA) µA) f 50 100 SMPL = 10.5kHz 180 49 48 140 47 10 46 SUPPLY CURRENT ( SUPPLY CURRENT ( REFERENCE CURRENT ( 100 45 44 1 60 43 0.1 1 10 100 – 55 – 35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 SAMPLE FREQUENCY (kHz) TEMPERATURE (°C) TEMPERATURE (°C) 1594L/98L G01 1594L/98L G02 1594L/98L G03 15948lfb 4
