Datasheet LTC1741 (Analog Devices) - 2
Description12-Bit, 65Msps Low Noise ADC
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. OVDD = VDD (Notes 1, …
File Format / SizePDF / 682 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. OVDD = VDD (Notes 1, 2). CO VERTER CHARACTERISTICS The
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION OVDD = VDD (Notes 1, 2) CO VERTER CHARACTERISTICS The
LTC1741
W W W U U W U ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION OVDD = VDD (Notes 1, 2)
ORDER PART Supply Voltage (VDD) ... 5.5V TOP VIEW NUMBER Analog Input Voltage (Note 3) .. – 0.3V to (VDD + 0.3V) SENSE 1 48 OF V 2 47 OGND Digital Input Voltage (Except OE) CM GND 3 46 D11 LTC1741CFW + (Note 3) .. – 0.3V to (V A 4 45 D10 DD + 0.3V) IN– LTC1741IFW A 5 44 IN D9 OE Input Voltage (Note 4) .. –0.3V to (VDD + 0.3V) GND 6 43 OVDD Digital Output Voltage ... – 0.3V to (V V 7 42 DD D8 DD + 0.3V) V 8 41 DD D7 OGND Voltage .. – 0.3V to 1V GND 9 40 D6 REFLB 10 39 D5 Power Dissipation .. 2000mW REFHA 11 38 OGND Operating Temperature Range GND 12 37 GND GND 13 36 GND LTC1741C ... 0°C to 70°C REFLA 14 35 D4 REFHB 15 34 D3 LTC1741I .. – 40°C to 85°C GND 16 33 D2 Storage Temperature Range ... – 65°C to 150°C V 17 32 DD OVDD V 18 31 DD D1 Lead Temperature (Soldering, 10 sec).. 300°C GND 19 30 D0 V 20 29 DD NC GND 21 28 NC MSBINV 22 27 OGND ENC 23 26 CLKOUT ENC 24 25 OE FW PACKAGE 48-LEAD PLASTIC TSSOP TJMAX = 150°C, θJA = 35°C/W Consult LTC Marketing for parts specified with wider operating temperature ranges.
U CO VERTER CHARACTERISTICS The
indicates specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. (Note 5) PARAMETER CONDITIONS MIN TYP MAX UNITS
Resolution (No Missing Codes) ● 12 Bits Integral Linearity Error (Note 6) ● – 1 ±0.4 1 LSB Differential Linearity Error ● –0.8 ±0.2 0.8 LSB Offset Error (Note 7) – 35 ±5 35 mV Gain Error External Reference (SENSE = 1.6V) – 3.5 ±1 3.5 %FS Full-Scale Drift Internal Reference ±40 ppm/°C External Reference (Sense = 1.6V) ±20 ppm/°C Offset Drift ±20 µV/°C Input Referred Noise (Transition Noise) Sense = 1.6V 0.21 LSBRMS
U U A ALOG I PUT The
C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN Analog Input Range (Note 8) 4.75V ≤ VDD ≤ 5.25V ● ±1 to ±1.6 V IIN Analog Input Leakage Current ● –1 1 µA CIN Analog Input Capacitance Sample Mode ENC < ENC 8 pF Hold Mode ENC > ENC 4 pF tACQ Sample-and-Hold Acquisition Time ● 5 7.3 ns tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Time Jitter 0.15 psRMS CMRR Analog Input Common Mode Rejection Ratio 1.5V < (A – + IN = AIN ) < 3V 80 dB 1741f 2
