Datasheet LTC1741 (Analog Devices) - 5
Description12-Bit, 65Msps Low Noise ADC
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 5:. Note 2:. Note 6:. Note 3:. …
File Format / SizePDF / 682 Kb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 5:. Note 2:. Note 6:. Note 3:. Note 7:. Note 4:. Note 8:. Note 9:
ELECTRICAL CHARACTERISTICS Note 1: Note 5: Note 2: Note 6: Note 3: Note 7: Note 4: Note 8: Note 9:
LTC1741
Note 5:
VDD = 5V, fSAMPLE = 65MHz, differential ENC/ENC = 2VP-P 65MHz of a device may be impaired. sine wave, input range = ±1.6V differential, unless otherwise specified.
Note 2:
All voltage values are with respect to ground with GND
Note 6:
Integral nonlinearity is defined as the deviation of a code from a (unless otherwise noted). straight line passing through the actual endpoints of the transfer curve.
Note 3:
When these pin voltages are taken below GND or above V The deviation is measured from the center of the quantization band. DD, they will be clamped by internal diodes. This product can handle input currents
Note 7:
Bipolar offset is the offset voltage measured from – 0.5 LSB of greater than 100mA below GND or above VDD without latchup. when the output code flickers between 0000 0000 0000 and
Note 4:
When this pin voltage is taken below GND or above 0V 1111 1111 1111. DD, it will be clamped by internal diodes. This product can handle input currents of
Note 8:
Guaranteed by design, not subject to test. >100mA below GND or above 0VDD without latchup.
Note 9:
Recommended operating conditions.
W U TYPICAL PERFOR A CE CHARACTERISTICS Averaged 8192 Point FFT, Input Frequency = 5MHz, –1dB, INL, 3.2V Range DNL, 3.2V Range 3.2V Range
1.0 1.0 0 –10 0.8 0.8 –20 0.6 0.6 –30 0.4 0.4 –40 0.2 0.2 –50 0 0 –60 –0.2 –0.2 –70 ERROR (LSB) ERROR (LSB) AMPLITUDE (dBFS) –80 –0.4 –0.4 –90 –0.6 –0.6 –100 –0.8 –0.8 –110 –1.0 –1.0 –120 0 1024 2048 3072 4096 0 1024 2048 3072 4096 0 5 10 15 20 25 30 OUTPUT CODE OUTPUT CODE FREQUENCY (MHz) 1741 G01 1741 G02 1741 G03
Averaged 8192 Point FFT, Averaged 8192 Point FFT, Averaged 8192 Point FFT, Input Frequency = 5MHz, –10dB, Input Frequency = 5MHz, – 20dB, Input Frequency = 20MHz, –1dB, 3.2V Range 3.2V Range 3.2V Range
0 0 0 –10 –10 –10 –20 –20 –20 –30 –30 –30 –40 –40 –40 –50 –50 –50 –60 –60 –60 –70 –70 –70 AMPLITUDE (dBFS) –80 AMPLITUDE (dBFS) –80 AMPLITUDE (dBFS) –80 –90 –90 –90 –100 –100 –100 –110 –110 –110 –120 –120 –120 0 5 10 15 20 25 30 0 5 10 15 20 25 30 0 5 10 15 20 25 30 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 1741 G01 1741 G01 1741 G01 1741f 5
