Datasheet LTC2142-12, LTC2141-12, LTC2140-12 (Analog Devices) - 7
Description12-Bit, 65Msps Low Power Dual ADCs
Pages / Page38 / 7 — POWER REQUIREMENTS. The. denotes the specifications which apply over the …
POWER REQUIREMENTS. The. denotes the specifications which apply over the full operating temperature
POWER REQUIREMENTS The denotes the specifications which apply over the full operating temperature
LTC2142-12/ LTC2141-12/LTC2140-12
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) LTC2142-12 LTC2141-12 LTC2140-12 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS CMOS Output Modes: Full Data Rate and Double Data Rate
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.1 1.8 1.9 1.1 1.8 1.9 1.1 1.8 1.9 V IVDD Analog Supply Current DC Input l 50.9 57 35.9 41 26.9 32 mA Sine Wave Input 51.3 36.2 27 mA IOVDD Digital Supply Current Sine Wave Input, OVDD = 1.2V 3.8 2.4 1.5 mA PDISS Power Dissipation DC Input l 91.6 103 64.6 74 48.4 57.6 mW Sine Wave Input, OVDD = 1.2V 96.9 68 50.4 mW
LVDS Output Mode
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.7 1.8 1.9 1.7 1.8 1.9 1.7 1.8 1.9 V IVDD Analog Supply Current Sine Input, 1.75mA Mode 52.6 37.4 28.3 mA Sine Input, 3.5mA Mode l 53.8 61 38.7 45 29.5 35.5 mA IOVDD Digital Supply Current Sine Input, 1.75mA Mode 30 29.6 29.3 mA (0VDD = 1.8V) Sine Input, 3.5mA Mode l 57.4 67 57.1 67 56.8 67 mA PDISS Power Dissipation Sine Input, 1.75mA Mode 149 121 104 mW Sine Input, 3.5mA Mode l 200 231 172 202 155 185 mW
All Output Modes
PSLEEP Sleep Mode Power 1 1 1 mW PNAP Nap Mode Power 10 10 10 mW PDIFFCLK Power Increase with Differential Encode Mode Enabled 20 20 20 mW (No Increase for Nap or Sleep Modes)
TIMING CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) LTC2142-12 LTC2141-12 LTC2140-12 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
fS Sampling Frequency (Note 10) l 1 65 1 40 1 25 MHz tL ENC Low Time (Note 8) Duty Cycle Stabilizer Off l 7.3 7.69 500 11.88 12.5 500 19 20 500 ns Duty Cycle Stabilizer On l 2 7.69 500 2 12.5 500 2 20 500 ns tH ENC High Time (Note 8) Duty Cycle Stabilizer Off l 7.3 7.69 500 11.88 12.5 500 19 20 500 ns Duty Cycle Stabilizer On l 2 7.69 500 2 12.5 500 2 20 500 ns tAP Sample-and-Hold 0 0 0 ns Acquisition Delay Time
SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Digital Data Outputs (CMOS Modes: Full Data Rate and Double Data Rate)
tD ENC to Data Delay CL = 5pF (Note 8) l 1.1 1.7 3.1 ns tC ENC to CLKOUT Delay CL = 5pF (Note 8) l 1 1.4 2.6 ns tSKEW DATA to CLKOUT Skew tD – tC (Note 8) l 0 0.3 0.6 ns Pipeline Latency Full Data Rate Mode 6 Cycles Double Data Rate Mode 6.5 Cycles 21421012fa 7
