Datasheet LTC2205, LTC2204 (Analog Devices) - 4
Description16-Bit, 65Msps ADCs
Pages / Page36 / 4 — DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the …
DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifi cations which apply over the full operating temperature range,
LTC2205/LTC2204
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS unless otherwise noted. (Note 4) LTC2204 LTC2205 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
SFDR Spurious Free 5MHz Input (2.25V Range, PGA = 0) 105 105 dB Dynamic Range 5MHz Input (1.5V Range, PGA = 1) 105 105 dB 4th Harmonic 15MHz Input (2.25V Range, PGA = 0) l 90 100 90 100 dB or Higher 15MHz Input (1.5V Range, PGA = 1) 100 100 dB 70MHz Input (2.25V Range, PGA = 0) 100 100 dB 70MHz Input (1.5V Range, PGA = 1) l 88.5 100 88.5 100 dB 140MHz Input (2.25V Range, PGA = 0) 97 97 dB 140MHz Input (1.5V Range, PGA = 1) 97 97 dB 170MHz Input (2.25V Range, PGA = 0) 95 95 dB 170MHz Input (1.5V Range, PGA = 1) 95 95 dB S/(N+D) Signal-to-Noise 5MHz Input (2.25V Range, PGA = 0) 79.1 79.0 dBFS Plus Distortion Ratio 5MHz Input (1.5V Range, PGA = 1) 76.5 76.4 dBFS 15MHz Input (2.25V Range, PGA = 0) l 77.5 79.0 77.4 78.9 dBFS 15MHz Input (2.25V Range, PGA = 0) 77.7 79.0 77.6 78.9 dBFS 15MHz Input (1.5V Range, PGA = 1) 76.5 76.4 dBFS 70MHz Input (2.25V Range, PGA = 0) 78.5 78.4 dBFS 70MHz Input (1.5V Range, PGA = 1) l 73.8 76.2 73.8 76.2 dBFS 70MHz Input (1.5V Range, PGA = 1) 74.2 76.2 74.2 76.2 dBFS 140MHz Input (2.25V Range, PGA = 0) 77.3 77.0 dBFS 140MHz Input (1.5V Range, PGA = 1) 75.4 75.3 dBFS 170MHz Input (2.25V Range, PGA = 0) 76.5 76.0 dBFS 170MHz Input (1.5V Range, PGA = 1) 75.4 75.2 dBFS SFDR Spurious Free 5MHz Input (2.25V Range, PGA = 0) 105 105 dBFS Dynamic Range 5MHz Input (1.5V Range, PGA = 1) 105 105 dBFS at –25dBFS 15MHz Input (2.25V Range, PGA = 0) 105 105 dBFS Dither “OFF” 15MHz Input (1.5V Range, PGA = 1) 105 105 dBFS 70MHz Input (2.25V Range, PGA = 0) 105 105 dBFS 70MHz Input (1.5V Range, PGA = 1) 105 105 dBFS 140MHz Input (2.25V Range, PGA = 0) 100 100 dBFS 140MHz Input (1.5V Range, PGA = 1) 100 100 dBFS 170MHz Input (2.25V Range, PGA = 0) 100 100 dBFS 170MHz Input (1.5V Range, PGA = 1) 100 100 dBFS SFDR Spurious Free 5MHz Input (2.25V Range, PGA = 0) 115 115 dBFS Dynamic Range 5MHz Input (1.5V Range, PGA = 1) 115 115 dBFS at –25dBFS 15MHz Input (2.25V Range, PGA = 0) l 98 115 98 115 dBFS Dither “ON” 15MHz Input (1.5V Range, PGA = 1) 115 115 dBFS 70MHz Input (2.25V Range, PGA = 0) 115 115 dBFS 70MHz Input (1.5V Range, PGA = 1) 115 115 dBFS 140MHz Input (2.25V Range, PGA = 0) 115 115 dBFS 140MHz Input (1.5V Range, PGA = 1) 115 115 dBFS 170MHz Input (2.25V Range, PGA = 0) 105 105 dBFS 170MHz Input (1.5V Range, PGA = 1) 105 105 dBFS 22054fc 4
