Datasheet LTC2205-14 (Analog Devices) - 4
Description | 14-Bit, 65Msps ADC |
Pages / Page | 28 / 4 — DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the … |
File Format / Size | PDF / 1.2 Mb |
DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the full operating temperature range,
LTC2205-14
DYNAMIC ACCURACY The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 103 dBc 4th Harmonic or Higher 5MHz Input (1.5V Range, PGA = 1) 103 dBc 15MHz Input (2.25V Range, PGA = 0) l 87 98 dBc 15MHz Input (1.5V Range, PGA = 1) 98 dBc 70MHz Input (2.25V Range, PGA = 0) 98 dBc 70MHz Input (1.5V Range, PGA = 1) l 86.5 98 dBc 140MHz Input (2.25V Range, PGA = 0) 95 dBc 140MHz Input (1.5V Range, PGA = 1) 95 dBc 170MHz Input (2.25V Range, PGA = 0) 93 dBc 170MHz Input (1.5V Range, PGA = 1) 93 dBc S/(N+D) Signal-to-Noise Plus Distortion Ratio 5MHz Input (2.25V Range, PGA = 0) 78.2 dBFS 5MHz Input (1.5V Range, PGA = 1) 75.9 dBFS 15MHz Input (2.25V Range, PGA = 0) l 76.7 78.1 dBFS 15MHz Input (2.25V Range, PGA = 0) 77.1 78.1 dBFS 15MHz Input (1.5V Range, PGA = 1) 75.9 dBFS 70MHz Input (2.25V Range, PGA = 0) 77.4 dBFS 70MHz Input (1.5V Range, PGA = 1) l 73.5 75.5 dBFS 70MHz Input (1.5V Range, PGA = 1) 74.0 75.5 dBFS 140MHz Input (2.25V Range, PGA = 0) 75.9 dBFS 140MHz Input (1.5V Range, PGA = 1) 74.7 dBFS 170MHz Input (2.25V Range, PGA = 0) 73.6 dBFS 170MHz Input (1.5V Range, PGA = 1) 73.2 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 103 dBFS at –25dBFS Dither “OFF” 5MHz Input (1.5V Range, PGA = 1) 103 dBFS 15MHz Input (2.25V Range, PGA = 0) 103 dBFS 15MHz Input (1.5V Range, PGA = 1) 103 dBFS 70MHz Input (2.25V Range, PGA = 0) 103 dBFS 70MHz Input (1.5V Range, PGA = 1) 103 dBFS 140MHz Input (2.25V Range, PGA = 0) 98 dBFS 140MHz Input (1.5V Range, PGA = 1) 98 dBFS 170MHz Input (2.25V Range, PGA = 0) 98 dBFS 170MHz Input (1.5V Range, PGA = 1) 98 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 113 dBFS at –25dBFS Dither “ON” 5MHz Input (1.5V Range, PGA = 1) 113 dBFS 15MHz Input (2.25V Range, PGA = 0) l 95 113 dBFS 15MHz Input (1.5V Range, PGA = 1) 113 dBFS 70MHz Input (2.25V Range, PGA = 0) 110 dBFS 70MHz Input (1.5V Range, PGA = 1) 110 dBFS 140MHz Input (2.25V Range, PGA = 0) 110 dBFS 140MHz Input (1.5V Range, PGA = 1) 110 dBFS 170MHz Input (2.25V Range, PGA = 0) 103 dBFS 170MHz Input (1.5V Range, PGA = 1) 103 dBFS 220514fb 4
