Datasheet LTC2208 (Analog Devices) - 4
Description | 16-Bit, 130Msps ADC |
Pages / Page | 32 / 4 — The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the … |
File Format / Size | PDF / 987 Kb |
The. DYNAMIC ACCURACY. denotes the specifi cations which apply over the full operating temperature range,
LTC2208
The DYNAMIC ACCURACY
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SFDR Spurious Free 5MHz Input (2.25V Range, PGA = 0) 100 dBc Dynamic Range 5MHz Input (1.5V Range, PGA = 1) 100 dBc 4th Harmonic 30MHz Input (2.25V Range, PGA = 0) l 90 100 dBc or Higher 30MHz Input (1.5V Range, PGA = 1) 100 dBc 70MHz Input (2.25V Range, PGA = 0) 100 dBc 70MHz Input (1.5V Range, PGA = 1) 100 dBc 140MHz Input (2.25V Range, PGA = 0) 95 dBc 140MHz Input (1.5V Range, PGA = 1) l 88 95 dBc 250MHz Input (2.25V Range, PGA = 0) 90 dBc 250MHz Input (1.5V Range, PGA = 1) 90 dBc S/(N+D) Signal-to-Noise 5MHz Input (2.25V Range, PGA = 0) 77.7 dBFS Plus Distortion Ratio 5MHz Input (1.5V Range, PGA = 1) 75.3 dBFS 30MHz Input (2.25V Range, PGA = 0) TA = 25°C 76.3 77.5 dBFS 30MHz Input (2.25V Range, PGA = 0) l 75.9 77.5 dBFS 30MHz Input (1.5V Range, PGA = 1) 75.2 dBFS 70MHz Input (2.25V Range, PGA = 0) 77.4 dBFS 70MHz Input (1.5V Range, PGA = 1) 75 dBFS 140MHz Input (2.25V Range, PGA = 0) 76.4 dBFS 140MHz Input (1.5V Range, PGA = 1) TA = 25°C 73.6 74.5 dBFS 140MHz Input (1.5V Range, PGA = 1) l 73.2 74.5 dBFS 250MHz Input (2.25V Range, PGA = 0) 73.6 dBFS 250MHz Input (1.5V Range, PGA = 1) 72.9 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 105 dBFS at –25dBFS 5MHz Input (1.5V Range, PGA = 1) 105 dBFS Dither “OFF” 30MHz Input (2.25V Range, PGA = 0) 105 dBFS 30MHz Input (1.5V Range, PGA = 1) 105 dBFS 70MHz Input (2.25V Range, PGA = 0) 105 dBFS 70MHz Input (1.5V Range, PGA = 1) 105 dBFS 14 0MHz Input (2.25V Range, PGA = 0) 100 dBFS 140MHz Input (1.5V Range, PGA = 1) 100 dBFS 250MHz Input (2.25V Range, PGA = 0) 100 dBFS 250MHz Input (1.5V Range, PGA = 1) 100 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 115 dBFS at –25dBFS 5MHz Input (1.5V Range, PGA = 1) 115 dBFS Dither “ON” 30MHz Input (2.25V Range, PGA = 0) l 100 115 dBFS 30MHz Input (1.5V Range, PGA = 1) 115 dBFS 70MHz Input (2.25V Range, PGA = 0) 115 dBFS 70MHz Input (1.5V Range, PGA = 1) 115 dBFS 140MHz Input (2.25V Range, PGA = 0) 110 dBFS 140MHz Input (1.5V Range, PGA = 1) 110 dBFS 250MHz Input (2.25V Range, PGA = 0) 105 dBFS 250MHz Input (1.5V Range, PGA = 1) 105 dBFS 2208fc 4
