Datasheet LTC2230, LTC2231 (Analog Devices) - 6
Description10-Bit, 135Msps ADCs
Pages / Page32 / 6 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 6:. Note 7:. Note 2:. Note 8:. …
File Format / SizePDF / 718 Kb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 6:. Note 7:. Note 2:. Note 8:. Note 9:. Note 3:. Note 10:. Note 4:. Note 11:. Note 5:. Note 12:
ELECTRICAL CHARACTERISTICS Note 1: Note 6: Note 7: Note 2: Note 8: Note 9: Note 3: Note 10: Note 4: Note 11: Note 5: Note 12:
LTC2230/LTC2231
Note 6:
Offset error is the offset voltage measured from –0.5 LSB when the may cause permanent damage to the device. Exposure to any Absolute output code flickers between 00 0000 0000 and 11 1111 1111 in 2’s Maximum Rating condition for extended periods may affect device complement output mode. reliability and lifetime.
Note 7:
Guaranteed by design, not subject to test.
Note 2:
All voltage values are with respect to ground with GND and OGND
Note 8:
Recommended operating conditions. wired together (unless otherwise noted).
Note 9:
VDD = 3.3V, fSAMPLE = 170MHz (LTC2230) or 135MHz (LTC2231),
Note 3:
When these pin voltages are taken below GND or above VDD, they will differential ENC+/ENC– = 2VP-P sine wave, input range = 1VP-P with differential be clamped by internal diodes. This product can handle input currents of drive, output CLOAD = 5pF. greater than 100mA below GND or above VDD without latchup.
Note 10:
SNR minimum and typical values are for LVDS mode. Typical values
Note 4:
VDD = 3.3V, fSAMPLE = 170MHz (LTC2230) or 135MHz (LTC2231), for CMOS mode are typically 0.1dB lower. LVDS outputs differential, ENC+/ENC– = 2VP-P sine wave, input range =
Note 11:
SFDR minimum values are for LVDS mode. Typical values are for 2VP-P with differential drive, unless otherwise noted. both LVDS and CMOS modes.
Note 5:
Integral nonlinearity is defined as the deviation of a code from a
Note 12:
SINAD minimum and typical values are for LVDS mode. Typical straight line passing through the actual endpoints of the transfer curve. The values for CMOS mode are typically 0.1dB lower. deviation is measured from the center of the quantization band.
W U TYPICAL PERFOR A CE CHARACTERISTICS LTC2230: Shorted Input Noise LTC2230: INL, 2V Range LTC2230: DNL, 2V Range Histogram
1.0 1.0 140000 0.8 0.8 131059 120000 0.6 0.6 0.4 0.4 100000 0.2 0.2 80000 0 0 COUNT 60000 – 0.2 – 0.2 ERROR (LSB) ERROR (LSB) – 0.4 – 0.4 40000 – 0.6 – 0.6 20000 – 0.8 – 0.8 6 7 – 1.0 – 1.0 0 0 256 512 768 1024 0 256 512 768 1024 513 514 515 OUTPUT CODE OUTPUT CODE CODE 2230 G01 2230 G02 2230 G23
LTC2230: SNR LTC2230: SNR LTC2230: SFDR (HD2 and HD3) vs Input Frequency, –1dB, vs Input Frequency, –1dB, vs Input Frequency, –1dB, 2V Range 1V Range 2V Range
63 63 90 85 62 62 80 75 61 61 70 60 60 65 SNR (dBFS) SNR (dBFS) SFDR (dBFS) 60 59 59 55 50 58 58 45 57 57 40 0 100 200 300 400 500 600 0 100 200 300 400 500 600 0 100 200 300 400 500 600 INPUT FREQUENCY (MHz) INPUT FREQUENCY (MHz) INPUT FREQUENCY (MHz) 2230 G03 2230 G04 2230 G05 22301fb 6
