LTC2232/LTC2233 UUA ALOG I PUT The ● denotes the specifications which apply over the full operating temperature range, otherwisespecifications are at TA = 25 ° C. (Note 4)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS V + – IN Analog Input Range (AIN – AIN ) 3.1V < VDD < 3.5V ● ±0.5 to ±1 V V + – IN, CM Analog Input Common Mode (AIN + AIN )/2 Differential Input ● 1 1.6 1.9 V Single Ended Input (Note 7) ● 0.5 1.6 2.1 V I + – IN Analog Input Leakage Current 0 < AIN , AIN < VDD ● –1 1 µA ISENSE SENSE Input Leakage 0V < SENSE < 1V ● –1 1 µA IMODE MODE Pin Pull-Down Current to GND 10 µA Full Power Bandwidth Figure 8 Test Circuit 775 MHz tAP Sample and Hold Acquisition Delay Time 0 ns tJITTER Sample and Hold Acquisition Delay Time Jitter 0.15 psRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB UWDY A IC ACCURACY The ● denotes the specifications which apply over the full operating temperature range,otherwise specifications are at TA = 25 ° C. AIN = –1dBFS. (Note 4)LTC2232LTC2233SYMBOLPARAMETERCONDITIONSMINTYPMAXMINTYPMAXUNITS SNR Signal-to-Noise Ratio 30MHz Input (1V Range) 59.8 59.9 dB 30MHz Input (2V Range) ● 60.4 61.3 60.4 61.3 dB 70MHz Input (1V Range) 59.8 59.8 dB 70MHz Input (2V Range) 61.2 61.3 dB 140MHz Input (1V Range) 59.8 59.8 dB 140MHz Input (2V Range) 61.2 61.2 dB 250MHz Input (1V Range) 59.6 59.7 dB 250MHz Input (2V Range) 61.1 61.2 dB SFDR Spurious Free Dynamic Range 30MHz Input (1V Range) 80 80 dB 30MHz Input (2V Range) ● 69 78 69 78 dB 70MHz Input (1V Range) 80 80 dB 70MHz Input (2V Range) 78 78 dB 140MHz Input (1V Range) 78 78 dB 140MHz Input (2V Range) 78 78 dB 250MHz Input (1V Range) 71 73 dB 250MHz Input (2V Range) 70 72 dB SFDR Spurious Free Dynamic Range 30MHz Input (1V Range) 86 86 dB 4th Harmonic or Higher 30MHz Input (2V Range) 86 86 dB 70MHz Input (1V Range) 86 86 dB 70MHz Input (2V Range) 86 86 dB 140MHz Input (1V Range) 86 86 dB 140MHz Input (2V Range) 86 86 dB 250MHz Input (1V Range) 86 86 dB 250MHz Input (2V Range) 86 86 dB S/(N+D) Signal-to-Noise Plus 30MHz Input (1V Range) 59.8 59.9 dB Distortion Ratio 30MHz Input (2V Range) ● 60.2 61.3 60.2 61.3 dB 70MHz Input (1V Range) 59.8 59.8 dB 70MHz Input (2V Range) 61.2 61.2 dB IMD Intermodulation Distortion fIN1 = 138MHz, fIN2 = 140MHz 81 81 dBc 22323fa 3
