Datasheet LTC2238, LTC2237, LTC2236 (Analog Devices) - 2
Description10-Bit, 65Msps Low Power 3V ADCs
Pages / Page28 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, …
File Format / SizePDF / 714 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. OVDD = VDD (Notes 1, 2). Order Options. CO VERTER CHARACTERISTICS The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO OVDD = VDD (Notes 1, 2) Order Options CO VERTER CHARACTERISTICS The
LTC2238/LTC2237/LTC2236
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO OVDD = VDD (Notes 1, 2)
TOP VIEW Supply Voltage (VDD) ... 4V Digital Output Ground Voltage (OGND) ... –0.3V to 1V DD CM V V SENSE MODE OF D9 D8 D7 32 31 30 29 28 27 26 25 Analog Input Voltage (Note 3) ... –0.3V to (VDD + 0.3V) AIN+ 1 24 D6 Digital Input Voltage .. –0.3V to (VDD + 0.3V) AIN– 2 23 D5 Digital Output Voltage .. –0.3V to (OV REFH 3 22 D4 DD + 0.3V) REFH 4 21 OVDD Power Dissipation .. 1500mW 33 REFL 5 20 OGND Operating Temperature Range REFL 6 19 D3 LTC2238C, LTC2237C, LTC2236C ... 0°C to 70°C V 7 18 DD D2 GND 8 17 D1 LTC2238I, LTC2237I, LTC2236I ..–40°C to 85°C 9 10 11 12 13 14 15 16 Storage Temperature Range ..–65°C to 125°C OE CLK NC NC NC NC D0 SHDN UH PACKAGE 32-LEAD (5mm × 5mm) PLASTIC QFN TJMAX = 125°C, θJA = 34°C/W EXPOSED PAD (PIN 33) IS GND MUST BE SOLDERED TO PCB ORDER PART NUMBER QFN PART MARKING* LTC2238CUH 2238 LTC2238IUH 2238 LTC2237CUH 2237 LTC2237IUH 2237 LTC2236CUH 2236 LTC2236IUH 2236
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container.
U CO VERTER CHARACTERISTICS The
C. (Note 4) LTC2238 LTC2237 LTC2236 PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
Resolution ● 10 10 10 Bits (No Missing Codes) Integral Differential Analog Input ● –0.5 ±0.1 0.5 –0.5 ±0.1 0.5 –0.5 ±0.1 0.5 LSB Linearity Error (Note 5) Differential Differential Analog Input ● –0.5 ±0.05 0.5 –0.5 ±0.05 0.5 –0.5 ±0.05 0.5 LSB Linearity Error Offset Error (Note 6) ● –12 ±2 12 –12 ±2 12 –12 ±2 12 mV Gain Error External Reference ● –2.5 ±0.5 2.5 –2.5 ±0.5 2.5 –2.5 ±0.5 2.5 %FS Offset Drift ±10 ±10 ±10 µV/°C Full-Scale Drift Internal Reference ±30 ±30 ±30 ppm/°C External Reference ±5 ±5 ±5 ppm/°C Transition Noise SENSE = 1V 0.07 0.07 0.07 LSBRMS 223876fa 2
