Datasheet LTC2269 (Analog Devices) - 4
Description16-Bit, 20Msps Low Noise ADC
Pages / Page32 / 4 — CONVERTER CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 775 Kb
CONVERTER CHARACTERISTICS. The. denotes the specifications which apply over the full operating
CONVERTER CHARACTERISTICS The denotes the specifications which apply over the full operating
LTC2269
Resolution (No Missing Codes) l 16 Bits Integral Linearity Error Differential Analog Input l –2.3 ±1 2.3 LSB (Note 6) Differential Linearity Error Differential Analog Input l –0.8 ±0.2 0.8 LSB Offset Error (Note 7) l –7 ±1.3 7 mV Gain Error Internal Reference ±1.2 %FS External Reference l –1.5 –0.2 1.1 %FS Offset Drift ±10 μV/°C Full-Scale Drift Internal Reference ±30 ppm/°C External Reference ±10 ppm/°C Transition Noise External Reference 1.44 LSBRMS
ANALOG INPUT The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 1.7V < VDD < 1.9V l 1 to 2.1 VP-P V + – IN(CM) Analog Input Common Mode (AIN + AIN )/2 Differential Analog Input (Note 8) l 0.65 VCM VCM + 200mV V VSENSE External Voltage Reference Applied to SENSE External Reference Mode l 0.625 1.250 1.300 V IINCM Analog Input Common Mode Current Per Pin, 20Msps 32 μA I + – IN1 Analog Input Leakage Current (No Encode) 0 < AIN , AIN < VDD l –1 1 μA IIN2 PAR/SER Input Leakage Current 0 < PAR/SER < VDD l –1 1 μA IIN3 SENSE Input Leakage Current 0.625 < SENSE < 1.3V l –2 2 μA tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Jitter Single-Ended Encode 85 fsRMS Differential Encode 100 fsRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB BW-3B Full Power Bandwidth Figure 5 Test Circuit 200 MHz
DYNAMIC ACCURACY The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. AIN = –1dBFS. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 1.4MHz Input 84.1 dBFS 5MHz Input l 82.1 84.1 dBFS 30MHz Input 83.8 dBFS 70MHz Input 82.7 dBFS SFDR Spurious Free Dynamic Range 1.4MHz Input 99 dBFS 2nd Harmonic 5MHz Input l 90 98 dBFS 30MHz Input 98 dBFS 70MHz Input 90 dBFS 2269f 4
