Datasheet LTC2281 (Analog Devices) - 3
DescriptionDual 10-Bit, 125Msps Low Power 3V ADC
Pages / Page24 / 3 — The. CONVERTER CHARACTERISTICS. denotes the specifi cations which apply …
File Format / SizePDF / 500 Kb
The. CONVERTER CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The CONVERTER CHARACTERISTICS denotes the specifi cations which apply over the full operating
LTC2281
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
Gain Matching External Reference ±0.3 %FS Offset Matching ±2 mV Transition Noise SENSE = 1V 0.08 LSBRMS
ANALOG INPUT The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN –AIN ) 2.85V < VDD < 3.4V (Note 7) ● ±0.5V to ±1V V V + – IN,CM Analog Input Common Mode (AIN +AIN )/2 Differential Input Drive (Note 7) ● 1 1.5 1.9 V Single Ended Input Drive (Note 7) ● 0.5 1.5 2 V I + – IN Analog Input Leakage Current 0V < AIN , AIN < VDD ● –1 1 μA ISENSE SENSEA, SENSEB Input Leakage 0V < SENSEA, SENSEB < 1V ● –3 3 μA IMODE MODE Input Leakage Current 0V < MODE < VDD ● –3 3 μA tAP Sample-and-Hold Acquisition Delay Time 0 ns tJITTER Sample-and-Hold Acquisition Delay Time Jitter 0.2 psRMS CMRR Analog Input Common Mode Rejection Ratio 80 dB Full Power Bandwidth Figure 8 Test Circuit 640 MHz
DYNAMIC ACCURACY The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input 61.6 dB 30MHz Input 61.6 dB 70MHz Input ● 60 61.5 dB 140MHz Input 61.4 dB SFDR Spurious Free Dynamic Range 5MHz Input 85 dB 2nd or 3rd Harmonic 30MHz Input 85 dB 70MHz Input ● 69 82 dB 140MHz Input 77 dB SFDR Spurious Free Dynamic Range 5MHz Input 85 dB 4th Harmonic or Higher 30MHz Input 85 dB 70MHz Input ● 75 85 dB 140MHz Input 85 dB S/(N+D) Signal-to-Noise Plus Distortion Ratio 5MHz Input 61.5 dB 30MHz Input 61.5 dB 70MHz Input ● 60 61.4 dB 140MHz Input 61.2 dB IMD Intermodulation Distortion fIN = 40MHz, 41MHz 80 dB Crosstalk fIN = 100MHz –110 dB 2281fb 3
