Datasheet LTC2301, LTC2305 (Analog Devices) - 4
Description2-Channel, 12-Bit ADCs with I2C Compatible Interface
Pages / Page26 / 4 — DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the …
File Format / SizePDF / 907 Kb
DYNAMIC ACCURACY. The. denotes the specifi cations which apply over the full operating temperature range,
DYNAMIC ACCURACY The denotes the specifi cations which apply over the full operating temperature range,
LTC2301/LTC2305
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C and AIN = –1dBFS. (Notes 4,9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SINAD Signal-to-(Noise + Distortion) Ratio fIN = 1kHz l 71 73.4 dB SNR Signal-to-Noise Ratio fIN = 1kHz l 71 73.5 dB THD Total Harmonic Distortion fIN = 1kHz l –91 –77 dB SFDR Spurious Free Dynamic Range fIN = 1kHz, First 5 Harmonics l 79 92 dB Channel-to-Channel Isolation fIN = 1kHz –109 dB Full Linear Bandwidth fIN = 1kHz 700 kHz –3dB Input Linear Bandwidth (Note 10) 25 MHz Aperture Delay 13 ns Transient Response Full-Scale Step 240 ns
INTERNAL REFERENCE CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Notes 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
VREF Output Voltage IOUT = 0 l 2.46 2.50 2.54 V VREF Output Tempco IOUT = 0 ±25 ppm/°C VREF Output Impedance –0.1mA ≤ IOUT ≤ 0.1mA 8 kΩ VREFCOMP Output Voltage IOUT = 0 4.096 V VREF Line Regulation VDD = 4.75V to 5.25V 0.8 mV/V
I2C INPUTS AND DIGITAL OUTPUTS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Notes 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage l 2.85 V VIL Low Level Input Voltage l 1.5 V VIHA High Level Input Voltage for Address Pins A1, A0 l 4.75 V VILA Low Level Input Voltage for Address Pins A1, A0 l 0.25 V RINH Resistance from A1, A0 to VDD to Set Chip l 10 kΩ Address Bit to 1 RINL Resistance from A1, A0 to GND to Set Chip l 10 kΩ Address Bit to 0 RINF Resistance from A1, A0 to GND or VDD to Set l 2 MΩ Chip Address Bit to Float II Digital Input Current VIN = VDD l –10 10 μA VHYS Hysteresis of Schmitt Trigger Inputs (Note 8) l 0.25 V VOL Low Level Output Voltage (SDA) I = 3mA l 0.4 V tOF Output Fall Time VIN(MIN) to VIL(MAX) Bus Load CB 10pF to 400pF (Note 11) l 20 + 0.1CB 250 ns tSP Input Spike Suppression l 50 ns CCAX External Capacitance Load on Chip Address Pins l 10 pF (A1, A0) for Valid Float 23015fb 4
