Datasheet LTC2392-16 (Analog Devices) - 2
Description16-Bit, 500ksps SAR ADC with 94dB SNR
Pages / Page26 / 2 — absolute maximum ratings (Notes 1, 2). pin conFiguration. orDer …
File Format / SizePDF / 321 Kb
absolute maximum ratings (Notes 1, 2). pin conFiguration. orDer inFormation LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absolute maximum ratings (Notes 1, 2) pin conFiguration orDer inFormation LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC2392-16
Supply Voltage (VAVP , VDVP , VOVP) ..6.0V Operating Temperature Range Analog Input Voltage (Note 3) LTC2392C .. 0°C to 70°C IN+, IN–, REFIN, CNVST ... (GND – 0.3V) to (VAVP + 0.3V) LTC2392I ...–40°C to 85°C Digital Input Voltage..(GND – 0.3V) to (VOVP + 0.3V) LTC2392H .. –40°C to 125°C Digital Output Voltage ...(GND – 0.3V) to (VOVP + 0.3V) Storage Temperature Range .. –65°C to 150°C Power Dissipation .. 500mW
pin conFiguration
TOP VIEW TOP VIEW P P P + – P VP VP VP + – VP GND AV AV AV GND IN IN GND AV REFSENSE REFIN REFOUT 48 GND 47 A 46 A 45 A 44 GND 43 IN 42 IN 41 GND 40 A 39 REFSENSE 38 REFIN 37 REFOUT 48 47 46 45 44 43 42 41 40 39 38 37 GND 1 36 VCM AVP 2 35 GND GND 1 36 VCM DVP 3 34 CNVST AVP 2 35 GND SER/PAR 4 33 PD DVP 3 34 CNVST GND 5 32 RESET SER/PAR 4 33 PD OB/2C 6 GND 5 32 RESET 49 31 CS OB/2C 6 31 CS GND GND 7 30 RD GND 7 30 RD BYTESWAP 8 29 BUSY BYTESWAP 8 29 BUSY D0 9 28 D15 D0 9 28 D15 D1 10 27 D14 D1 10 27 D14 D2 11 26 D13 D2 11 26 D13 D3 12 25 D12 D3 12 25 D12 13 17 19 20 D4 D5 14 D6 15 D7 16 OVP 18 DVP D8 21 13 14 15 16 17 18 19 20 21 22 23 24 OGND GND D4 D5 D6 D7 D8 D9/SDIN 22 OVP DVP GND D11/SCLK 24 OGND D10/SDOUT 23 D9/SDIN UK PACKAGE D11/SCLK 48-LEAD (7mm × 7mm) PLASTIC QFN D10/SDOUT LX PACKAGE T 48-LEAD (7mm × 7mm) PLASTIC LQFP JMAX = 125°C, θJA = 29°C/W EXPOSED PAD (PIN 49) IS GND, MUST BE SOLDERED TO PCB TJMAX = 150°C, θJA = 55°C/W
orDer inFormation LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2392CUK-16#PBF LTC2392CUK-16#TRPBF LTC2392UK-16 48-Lead 7mm × 7mm Plastic QFN 0°C to 70°C LTC2392IUK-16#PBF LTC2392IUK-16#TRPBF LTC2392UK-16 48-Lead 7mm × 7mm Plastic QFN –40°C to 85°C
LEAD FREE FINISH TRAY PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC2392CLX-16#PBF LTC2392CLX-16#PBF LTC2392LX-16 48-Lead 7mm × 7mm Plastic LQFP 0°C to 70°C LTC2392ILX-16#PBF LTC2392ILX-16#PBF LTC2392LX-16 48-Lead 7mm × 7mm Plastic LQFP –40°C to 85°C LTC2392HLX-16#PBF LTC2392HLX-16#PBF LTC2392LX-16 48-Lead 7mm × 7mm Plastic LQFP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 239216fa 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Analog Input Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagrams Applications Information Package Description Revision History Typical Application Related Parts
