Datasheet LTC2413 (Analog Devices) - 5
Description24-Bit No Latency ∆Σ™ ADC with Simultaneous 50Hz/60Hz Rejection
Pages / Page46 / 5 — igiTal inpuTs anD ouTpuTs The. denotes the specifications which apply …
File Format / SizePDF / 526 Kb
igiTal inpuTs anD ouTpuTs The. denotes the specifications which apply over the full operating
igiTal inpuTs anD ouTpuTs The denotes the specifications which apply over the full operating
LTC2413
D igiTal inpuTs anD ouTpuTs The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VIH High Level Input Voltage 2.7V ≤ VCC ≤ 5.5V l 2.5 V CS, FO 2.7V ≤ VCC ≤ 3.3V 2.0 V VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V l 0.8 V CS, FO 2.7V ≤ VCC ≤ 5.5V 0.6 V VIH High Level Input Voltage 2.7V ≤ VCC ≤ 5.5V (Note 8) l 2.5 V SCK 2.7V ≤ VCC ≤ 3.3V (Note 8) 2.0 V VIL Low Level Input Voltage 4.5V ≤ VCC ≤ 5.5V (Note 8) l 0.8 V SCK 2.7V ≤ VCC ≤ 5.5V (Note 8) 0.6 V IIN Digital Input Current 0V ≤ VIN ≤ VCC l –10 10 µA CS, FO Digital Input Current 0V ≤ VIN ≤ VCC (Note 8) l –10 10 µA SCK CIN Digital Input Capacitance 10 pF CS, FO Digital Input Capacitance (Note 8) 10 pF SCK VOH High Level Output Voltage IO = –800µA l VCC – 0.5V V SDO VOL Low Level Output Voltage IO = 1.6mA l 0.4 V SDO VOH High Level Output Voltage IO = –800µA (Note 9) l VCC – 0.5V V SCK VOL Low Level Output Voltage IO = 1.6mA (Note 9) l 0.4 V SCK IOZ Hi-Z Output Leakage l –10 10 µA SDO
power requireMenTs The
VCC Supply Voltage l 2.7 5.5 V ICC Supply Current Conversion Mode CS = 0V (Note 11) l 200 300 µA Sleep Mode CS = V 20 30 µA CC (Note 11) l 2413fa For more information www.linear.com/LTC2413 5
