Datasheet LTC2452 (Analog Devices) - 4
DescriptionUltra-Tiny, Differential, 16-Bit ΔΣ ADC with SPI Interface
Pages / Page22 / 4 — TiMing characTerisTics The. denotes the specifications which apply over …
File Format / SizePDF / 491 Kb
TiMing characTerisTics The. denotes the specifications which apply over the full operating temperature
TiMing characTerisTics The denotes the specifications which apply over the full operating temperature
LTC2452
denotes the specifications which apply over the full operating temperature range,otherwise specifications are at TA = 25°C. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tCONV Conversion Time l 13 16.6 23 ms fSCK SCK Frequency Range l 2 MHz tlSCK SCK Low Period l 250 ns thSCK SCK High Period l 250 ns t1 CS Falling Edge to SDO Low-Z (Notes 7, 8) l 0 100 ns t2 CS Rising Edge to SDO Hi-Z (Notes 7, 8) l 0 100 ns t3 CS Falling Edge to SCK Falling Edge l 100 ns tKQ SCK Falling Edge to SDO Valid (Note 7) l 0 100 ns
Note 1:
Note 5:
CS = VCC. A positive current is flowing into the DUT pin. may cause permanent damage to the device. Exposure to any Absolute
Note 6:
SCK = VCC or GND. SDO is high impedance. Maximum Rating condition for extended periods may affect device
Note 7:
See Figure 4. reliability and lifetime.
Note 8:
See Figure 5.
Note 2.
All voltage values are with respect to GND. VCC = 2.7V to 5.5V
Note 9:
Input sampling current is the average input current drawn from the unless otherwise specified. input sampling network while the LTC2452 is actively sampling the input. VREFCM = VREF/2, FS = VREF
Note 10:
A positive current is flowing into the DUT pin. V + – + – IN = VIN – VIN , –VREF ≤ VIN ≤ VREF; VINCM = (VIN + VIN )/2.
Note 3.
Guaranteed by design, not subject to test.
Note 4.
Integral nonlinearity is defined as the deviation of a code from a straight line passing through the actual endpoints of the transfer curve. Guaranteed by design and test correlation.
Typical perForMance characTerisTics (TA = 25°C, unless otherwise noted) Integral Nonlinearity, VCC = 5V Integral Nonlinearity, VCC = 3V Maximum INL vs Temperature
3 3 3 2 2 2 1 TA = 90°C 1 1 V T CC = VREF = 5V, 4.1V, 3V A = –45°C, 25°C, 90°C 0 0 0 INL (LSB) TA = –45°C, 25°C INL (LSB) INL (LSB) –1 –1 –1 –2 –2 –2 –3 –3 –3 –5 –4 –3 –2 –1 0 1 2 3 4 5 –3 –2 –1 0 1 2 3 –50 –25 0 25 50 75 100 DIFFERENTIAL INPUT VOLTAGE (V) DIFFERENTIAL INPUT VOLTAGE (V) TEMPERATURE (°C) 2452 G01 2452 G02 2452 G03 2452fd 4 For more information www.linear.com/LTC2452
