Datasheet LTC2493 (Analog Devices) - 8
Description24-Bit 2-/4-Channel ∆Σ ADC with Easy Drive Input Current Cancellation and I2C Interface
Pages / Page32 / 8 — Typical perForMance characTerisTics. On-Chip Oscillator Frequency. vs …
File Format / SizePDF / 552 Kb
Typical perForMance characTerisTics. On-Chip Oscillator Frequency. vs Temperature. vs VCC. PSRR vs Frequency at VCC
Typical perForMance characTerisTics On-Chip Oscillator Frequency vs Temperature vs VCC PSRR vs Frequency at VCC
LTC2493
Typical perForMance characTerisTics On-Chip Oscillator Frequency On-Chip Oscillator Frequency vs Temperature vs VCC PSRR vs Frequency at VCC
310 310 0 VREF = 2.5V VCC = 4.1V DC ±0.7V VIN = 0V V –20 REF = 2.5V 308 V IN+ = GND 308 IN(CM) = GND fO = GND IN– = GND TA = 25°C –40 fO = GND T 306 A = 25°C 306 –60 304 –80 304 FREQUENCY (kHz) REJECTION (dB) V FREQUENCY (kHz) CC = 4.1V –100 V 302 REF = 2.5V VIN = 0V 302 V –120 IN(CM) = GND fO = GND 300 300 –140 –45 –30 –15 0 15 30 45 60 75 90 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1 10 100 1k 10k 100k 1M TEMPERATURE (°C) VCC (V) FREQUENCY AT VCC (Hz) 2493 G19 2493 G20 2493 G21
Conversion Current PSRR vs Frequency at VCC PSRR vs Frequency at VCC vs Temperature
0 0 200 VCC = 4.1V DC ±1.4V VCC = 4.1V DC ±0.7V fO = GND V V –20 REF = 2.5V REF = 2.5V IN+ = GND –20 IN+ = GND IN– = GND IN– = GND 180 –40 fO = GND –40 fO = GND VCC = 5V TA = 25°C TA = 25°C –60 –60 160 –80 –80 VCC = 2.7V 140 REJECTION (dB) REJECTION (dB) –100 –100 CONVERSION CURRENT (µA) 120 –120 –120 –140 –140 100 0 20 40 60 80 100 120 140 160 180 200 220 30600 30650 30700 30750 30800 –45 –30 –15 0 15 30 45 60 75 90 FREQUENCY AT VCC (Hz) FREQUENCY AT VCC (Hz) TEMPERATURE (°C) 2493 G22 2493 G23 2493 G24
Sleep Mode Current Conversion Current Integral Nonlinearity (2x Speed vs Temperature vs Output Data Rate Mode; VCC = 5V, VREF = 5V)
2.0 500 3 fO = GND VREF = VCC V 1.8 CC = 5V 450 IN+ = GND VREF = 5V 1.6 IN– = GND 2 VIN(CM) = 2.5V 400 fO = EXT OSC fO = GND 1.4 TA = 25°C 1 1.2 350 VCC = 5V V) 25°C, 85°C 1.0 300 0 0.8 Y CURRENT (µA) INL (µ 250 0.6 V –1 CC = 2.7V SUPPL V 200 CC = 5V SLEEP MODE CURRENT (µA) 0.4 –45°C –2 0.2 150 VCC = 3V 0 100 –3 –45 –30 –15 0 15 30 45 60 75 90 0 10 20 30 –2.5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 2.5 TEMPERATURE (°C) OUTPUT DATA RATE (READINGS/SEC) INPUT VOLTAGE (V) 2493 G25 2493 G26 2493 G27 2493fe 8 For more information www.linear.com/LTC2493 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics (Normal Speed) Electrical Characteristics (2x Speed) Converter Characteristics Analog Input and Reference I2C Inputs and Digital Outputs Power Requirements Digital Inputs and Digital Outputs I2C Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Package Description Revision History Typical Application Related Parts
