Datasheet LTM9013 (Analog Devices) - 8
Description | 300MHz Wideband Receiver |
Pages / Page | 38 / 8 — Typical perForMance characTerisTics. 64k Point FFT, fIN = 1950MHz,. 64K … |
File Format / Size | PDF / 978 Kb |
Typical perForMance characTerisTics. 64k Point FFT, fIN = 1950MHz,. 64K Point FFT, fIN = 1925MHz,
LTM9013
Typical perForMance characTerisTics 64k Point FFT, fIN = 1950MHz, 64K Point FFT, fIN = 1925MHz, Baseband Frequency Response –1dBFS 1975MHz, –7dBFS per Tone
0 0 0 –10 –10 –1 –20 –20 –30 –30 –2 –40 –40 –50 –50 –3 –60 –60 –70 –70 AMPLITUDE (dB) –4 AMPLITUDE (dBFS) –80 AMPLITUDE (dBFS) –80 –90 –90 –5 –100 –100 –110 –110 –6 –120 –120 0 50 100 150 200 250 300 350 400 450 500 0 16 32 48 64 80 96 112 128 144 160 0 16 32 48 64 80 96 112 128 144 160 BASEBAND FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 9013 G01 9013 G02 9013 G03
SNR at 150MHz IF vs RF Drive HD2 at 150MHz IF vs LO Power HD2 at 150MHz IF vs RF Drive
61.0 –45 –40 60.5 –50 –45 –55 60.0 HD2, Q CHANNEL –50 –60 HD2, Q CHANNEL 59.5 HD2, I CHANNEL –55 SNR (dB) HD2 (dBc) –65 HD2 (dBc) 59.0 –60 –70 HD2, I CHANNEL 58.5 –75 –65 58.0 –80 –70 –5 0 5 10 15 –22 –18 –14 –10 –6 –2 2 6 10 –5 0 5 10 15 RF DRIVE (dBm) LO POWER (dBm) RF DRIVE (dBm) 9013 G04 9013 G05 9013 G06
HD3 at 150MHz IF vs RF Drive IM3 at 150MHz vs RF Drive LO to RF Isolation
–40 –40 0 –45 –45 –10 –50 –50 –20 –55 –30 –55 –60 –40 –60 HD3 (dBc) IM3 (dBc) –65 ISOLATION (dB) –50 –65 –70 –60 –70 –75 –70 –75 –80 –80 –5 0 5 10 15 –12 –10 –8 –6 –4 –2 0 2 4 6 8 10 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.3 2.4 2.5 RF DRIVE (dBm) RF DRIVE PER TONE (dBm) LO FREQUENCY (GHz) 9013 G07 9013 G08 9013 G09 9013fa 8 For more information www.linear.com/LTM9013 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Dynamic Accuracy Analog Inputs and Outputs Digital Inputs and Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Block Diagram Timing Diagrams Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
