Datasheet LTC1390 (Analog Devices) - 2
Description8-Channel Analog Multiplexer with Serial Interface
Pages / Page8 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL …
RevisionLTC1390: 8-Channel Analog Multiplexer with Serial Interface Data Sheet
File Format / SizePDF / 167 Kb
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). ELECTRICAL CH. ARA TERISTICS
ABSOLUTE AXI U R TI GS PACKAGE/ORDER I FOR ATIO (Note 1) ELECTRICAL CH ARA TERISTICS
LTC1390
W W W U U W U ABSOLUTE AXI U A R TI GS PACKAGE/ORDER I FOR ATIO (Note 1)
Total Supply Voltage (V+ to V–) .. 15V TOP VIEW ORDER PART Input Voltage S0 1 16 V+ NUMBER Analog Inputs .. V – – 0.3V to V+ + 0.3V S1 2 15 D Digital Inputs .. – 0.3V to 15V S2 3 14 V – LTC1390CN Digital Outputs ... – 0.3V to V + + 0.3V S3 4 13 DATA 2 LTC1390CS Power Dissipation ... 500mW S4 5 12 DATA 1 Operating Temperature Range ... 0°C to 70°C S5 6 11 CS Storage Temperature Range ... – 65°C to 150°C S6 7 10 CLK Lead Temperature (Soldering, 10 sec)... 300°C S7 8 9 GND N PACKAGE S PACKAGE 16-LEAD PDIP 16-LEAD PLASTIC SO TJMAX = 150°C, θJA = 70°C/ W (N) TJMAX = 150°C, θJA = 100°C/ W (S) Consult factory for Industrial and Military grade parts.
ELECTRICAL CH C ARA TERISTICS V+ = 5V, V– = – 5V, GND = 0V, TA = operating temperature unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Switch
VANALOG Analog Signal Range (Note 2) ● – 5 5 V RON On Resistance VS = ±3.5V, ID = 1mA TMIN 75 Ω 25°C 45 75 Ω TMAX 120 Ω ∆RON vs VS 20 % ∆RON vs Temperature 0.5 %/°C IS(OFF) Off Input Leakage VS = 4V, VD = – 4V; VS = – 4V, VD = 4V 0.05 ±5 nA Channel Off ● ±50 nA ID(OFF) Off Output Leakage VS = 4V, VD = – 4V; VS = – 4V, VD = 4V 0.05 ±5 nA Channel Off ● ±50 nA ID(ON) On Channel Leakage VS = VD = ±4V 0.05 ±5 nA Channel On ● ±50 nA
Input
VINH High Level Input Voltage V+ = 5.25V ● 2.4 V VINL Low Level Input Voltage V+ = 4.75V ● 0.8 V IINL, IINH Low or High Level Current VIN = 5V, VIN = 0V ● ±1 µA VOH High Level Output Voltage V+ = 4.75V, IO = 10µA 4.74 V V+ = 4.75V, IO = 360µA ● 2.4 4.50 V VOL Low Level Output Voltage V+ = 4.75V, IO = 0.5mA ● 0.16 0.8 V sn1390 1390fs 2
