Datasheet LTC1390 (Analog Devices) - 8
Description8-Channel Analog Multiplexer with Serial Interface
Pages / Page8 / 8 — TYPICAL APPLICATIONS N. Interfacing LTC1390 with LTC1257 for Demultiplex …
RevisionLTC1390: 8-Channel Analog Multiplexer with Serial Interface Data Sheet
File Format / SizePDF / 167 Kb
TYPICAL APPLICATIONS N. Interfacing LTC1390 with LTC1257 for Demultiplex Operation
TYPICAL APPLICATIONS N Interfacing LTC1390 with LTC1257 for Demultiplex Operation
LTC1390
U TYPICAL APPLICATIONS N Interfacing LTC1390 with LTC1257 for Demultiplex Operation
VCC VEE OPTIONAL D/A OUTPUT FILTER 1 16 S0 V + 2 15 S1 D VCC 3 LTC1390 14 VCC S2 V – 1 8 CLK V 4 13 47k CC S3 DATA 2 LTC1257 ANALOG 2 7 5 12 D V OUTPUTS IN OUT S4 DATA 1 3 6 6 11 LOAD V S5 CS REF 7 10 4 5 S6 CLK DOUT GND 8 9 S7 GND DATA CLK CS LTC1390 • F03
U PACKAGE DESCRIPTION Dimensions in inches (millimeters) unless otherwise noted. N Package 16-Lead Plastic DIP
0.770* (19.558) 0.300 – 0.325 0.130 ± 0.005 0.045 – 0.065 MAX (7.620 – 8.255) (3.302 ± 0.127) (1.143 – 1.651) 16 15 14 13 12 11 10 9 0.015 (0.381) 0.255 ± 0.015* MIN 0.065 (6.477 ± 0.381) 0.009 – 0.015 (1.651) (0.229 – 0.381) TYP +0.025 0.125 0.325 1 2 3 4 5 6 7 8 –0.015 (3.175) 0.045 ± 0.015 0.018 ± 0.003 +0.635 MIN 8.255 ( ) (1.143 ± 0.381) (0.457 ± 0.076) –0.381 0.100 ± 0.010 (2.540 ± 0.254) *THESE DIMENSIONS DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.010 INCH (0.254mm).
S Package 16-Lead Plastic SOIC
0.386 – 0.394* (9.804 – 10.008) 0.010 – 0.020 × 45° 16 15 14 13 12 11 10 9 0.053 – 0.069 0.004 – 0.010 (0.254 – 0.508) (1.346 – 1.752) (0.101 – 0.254) 0.008 – 0.010 (0.203 – 0.254) 0° – 8° TYP 0.228 – 0.244 0.150 – 0.157* (5.791 – 6.197) (3.810 – 3.988) 0.014 – 0.019 0.050 0.016 – 0.050 (0.355 – 0.483) (1.270) 0.406 – 1.270 TYP *THESE DIMENSIONS DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.006 INCH (0.15mm). 1 2 3 4 5 6 7 8
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC201A/LTC202/LTC203 Micropower, Low Charge Injection, Quad CMOS Analog Switches Each Channel is Independently Controlled LTC221/LTC222 Micropower, Low Charge Injection, Quad CMOS Analog Switches Parallel Controlled with Data Latches with Data Latches LTC128x/LTC129x Serial A/Ds with Integral MUXs sn1390 1390fs LT/GP 0695 10K • PRINTED IN THE USA 8 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7487 (408) 432-1900 ● FAX: (408) 434-0507 ● TELEX: 499-3977 LINEAR TECHNOLOGY CORPORATION 1995
