LTC1391 WUTYPICAL PERFOR A CE CHARACTERISTICSDriver Output High VoltageDriver Output High Voltagevs Output Currentvs Temperature 0 5.0 4.5 V+ = 5V –0.5 V+ = 2.7V V – = –5V V – = 0V 4.0 IO = 1.6mA –1.0 3.5 –1.5 3.0 V+ = 5V –2.0 V – = –5V 2.5 2.0 V+ = 2.7V –2.5 V – = 0V OUTPUT VOLTAGE (V) 1.5 IO = 400µA OUTPUT CURRENT (mA) –3.0 1.0 –3.5 T 0.5 A =25°C –4.0 0 2.0 2.5 3.0 3.5 4.0 4.5 5.0 –40 –20 0 20 40 60 80 OUTPUT VOLTAGE (V) TEMPERATURE (°C) 1391 G04 1391 G05 UUUPIN FUNCTIONSS0, S1, S2, S3, S4, S5, S6, S7 (Pins 1, 2, 3, 4, 5, 6, 7,DIN (Pin 12): Digital Input (TTL/CMOS Compatible). Input 8): Analog Multiplexer Inputs. for the channel selection bits. GND (Pin 9): Digital Ground. Connect to system ground. DOUT (Pin 13): Digital Output (TTL/CMOS Compatible). Output from the internal shift register. CLK (Pin 10): System Clock (TTL/CMOS Compatible). The clock synchronizes the channel selection bits and the V – (Pin 14): Negative Supply. For ±5V dual supply appli- serial data transfer from DIN to DOUT. cations, |V– | should not exceed |V+|by more than 20% for proper channel selection. CS (Pin 11): Channel Select Input (TTL/CMOS Compat- ible). A logic high on this input enables the LTC1391 to D (Pin 15): Analog Multiplexer Output. read in the channel selection bits and allows digital data V + (Pin 16): Positive Supply. transfer from DIN to DOUT. A logic low on this input puts DOUT into three-state and enables the selected channel for analog signal transmission. sn1391 1391fas 5
