Datasheet LT1086 (Analog Devices) - 14
Description1.5A Low Dropout Positive Regulators Adjustable and Fixed 2.85V, 3.3V, 3.6V, 5V, 12V
Pages / Page16 / 14 — TYPICAL APPLICATIONS. Battery Backed Up Regulated Supply. Improving …
File Format / SizePDF / 227 Kb
TYPICAL APPLICATIONS. Battery Backed Up Regulated Supply. Improving Ripple Rejection. Automatic Light Control
TYPICAL APPLICATIONS Battery Backed Up Regulated Supply Improving Ripple Rejection Automatic Light Control
LT1086 Series
U TYPICAL APPLICATIONS Battery Backed Up Regulated Supply Improving Ripple Rejection
5.2V LINE V V IN OUT IN IN LT1086-5 OUT IN ≥ 6.5V LT1086 VOUT = 5V 5V BATTERY + R1 ADJ 10µF GND 121Ω + 1% 10µF 50Ω 150µF R2 + SELECT FOR C1 365Ω CHARGE RATE 10µF* 1% IN LT1086-5 OUT LT1086 • TA14 + + *C1 IMPROVES RIPPLE REJECTION. 6.5V 10µF GND 100µF XC SHOULD BE ≈ R1 AT RIPPLE FREQUENCY LT1086 • TA13
Automatic Light Control Low Dropout Negative Supply
V IN IN LT1086 OUT V ADJ IN 1.2k + IN LT1086-12 OUT 10µF 100µF GND + + 10,000µF 100µF VOUT = –12V LT1086 • TA15 LT1086 • TA16 FLOATING INPUT
U PACKAGE DESCRIPTION H Package 3-Lead TO-39 Metal Can
(Reference LTC DWG # 05-08-1330) 0.350 – 0.370 (8.890 – 9.398) 0.200 0.305 – 0.335 (5.080) (7.747 – 8.509) 0.100 TYP 0.050 (2.540) (1.270) MAX 0.165 – 0.185 (4.191 – 4.699) PIN 1 REFERENCE 0.029 – 0.045 PLANE * (0.737 – 1.143) 0.100 (2.540) 0.028 – 0.034 (0.711 – 0.864) 0.016 – 0.021** 0.500 (0.406 – 0.533) (12.700) DIA MIN 45° H3(TO-39) 1098 *LEAD DIAMETER IS UNCONTROLLED BETWEEN THE REFERENCE PLANE AND 0.045" BELOW THE REFERENCE PLANE 0.016 – 0.024 **FOR SOLDER DIP LEAD FINISH, LEAD DIAMETER IS (0.406 – 0.610)
OBSOLETE PACKAGE
sn1086 1086ffs 14
