Datasheet LT1585-1.5, LT1585A-1.5 (Analog Devices) - 7
Description | Fixed 1.5V, 4.6A and 5A Low Dropout, Fast Response GTL+ Regulators |
Pages / Page | 8 / 7 — PACKAGE DESCRIPTION Dimensions in inches (millimeters) unless otherwise … |
File Format / Size | PDF / 156 Kb |
PACKAGE DESCRIPTION Dimensions in inches (millimeters) unless otherwise noted. M Package. 3-Lead Plastic DD Pak. T Package
LT1585-1.5/LT1585A-1.5
U PACKAGE DESCRIPTION Dimensions in inches (millimeters) unless otherwise noted. M Package 3-Lead Plastic DD Pak
(LTC DWG # 05-08-1460) 0.060 (1.524) 0.390 – 0.415 0.060 TYP (9.906 – 10.541) 0.165 – 0.180 0.256 (1.524) (6.502) (4.191 – 4.572) 0.045 – 0.055 (1.143 – 1.397) 15° TYP +0.008 0.004 0.060 –0.004 0.183 0.059 0.330 – 0.370 (1.524) (4.648) (1.499) (8.382 – 9.398) TYP ( +0.203 0.102 –0.102) 0.095 – 0.115 (2.413 – 2.921) 0.075 (1.905) 0.090 – 0.110 0.050 ± 0.012 0.300 +0.012 0.143 (2.286 – 2.794) 0.013 – 0.023 (7.620) – 0.020 (1.270 ± 0.305) 0.050 (0.330 – 0.584) +0.305 BOTTOM VIEW OF DD PAK 3.632 (1.270) ( –0.508) HATCHED AREA IS SOLDER PLATED M (DD3) 1098 BSC COPPER HEAT SINK
T Package 3-Lead Plastic TO-220
(LTC DWG # 05-08-1420) 0.147 – 0.155 0.165 – 0.180 0.390 – 0.415 (3.734 – 3.937) (4.191 – 4.572) (9.906 – 10.541) 0.045 – 0.055 DIA (1.143 – 1.397) 0.230 – 0.270 (5.842 – 6.858) 0.570 – 0.620 0.460 – 0.500 (14.478 – 15.748) (11.684 – 12.700) 0.330 – 0.370 (8.382 – 9.398) 0.980 – 1.070 (24.892 – 27.178) 0.520 – 0.570 (13.208 – 14.478) 0.218 – 0.252 (5.537 – 6.401) 0.013 – 0.023 0.100 (0.330 – 0.584) (2.540) 0.095 – 0.115 0.050 BSC (2.413 – 2.921) 0.028 – 0.038 (1.270) (0.711 – 0.965) TYP T3 (TO-220) 1098 Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no represen- tation that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7
