Datasheet LT3007 (Analog Devices)
Description3μA IQ, 20mA, 45V Low Dropout Fault Tolerant Linear Regulators
Pages / Page20 / 1 — FEATURES. DESCRIPTION. FMEA Fault Tolerant:. Output Stays at or Below …
File Format / SizePDF / 344 Kb
FEATURES. DESCRIPTION. FMEA Fault Tolerant:. Output Stays at or Below Regulation Voltage During
Datasheet LT3007 Analog Devices
LT3007
LT3007 Series
LT3007 Series 3µA IQ, 20mA, 45V Low Dropout Fault Tolerant Linear Regulators
FEATURES DESCRIPTION
n
The LT®3007 series are micropower, low dropout voltage
(LDO) linear regulators. The devices supply 20mA output
Adjacent Pin Short or if a Pin Is Left Floating
current with a dropout voltage of 300mV. No-load quies- n
Ultralow Quiescent Current: 3µA
cent current is 3µA. Ground pin current remains at less n
Input Voltage Range: 2.0V to 45V
than 5% of output current as load increases. In shutdown, n
Output Current: 20mA
quiescent current is less than 1µA. n
Dropout Voltage: 300mV
The LT3007 regulators optimize stability and transient n
Adjustable Output (VADJ = VOUT(MIN) = 600mV)
response with low ESR ceramic capacitors, requiring a n
Fixed Output Voltages: 1.2V, 1.5V, 1.8V, 2.5V, 3.3V, 5V
minimum of only 2.2µF. The regulators do not require n Output Tolerance: ±2% Over Load, Line and the addition of ESR as is common with other regulators. Temperature Internal protection circuitry includes current limiting, n Stable with Low ESR, Ceramic Output Capacitors thermal limiting, reverse-battery protection and reverse- (2.2µF Minimum) current protection. n Shutdown Current: <1µA n Current Limit Protection The LT3007 series are ideal for applications that require n Reverse-Battery Protection moderate output drive capability coupled with ultralow n Thermal Limit Protection standby power consumption. The device is available in n TSOT-23 Package fixed output voltages of 1.2V, 1.5V, 1.8V, 2.5V, 3.3V and 5V, and an adjustable version with an output voltage range
of 0.6V to 44.5V. The LT3007 is available in the thermally enhanced 8-lead TSOT-23 package. n Automotive L, LT, LTC, LTM, Linear Technology and the Linear logo are registered and ThinSOT is a n Low Current Battery-Powered Systems trademark of Linear Technology Corporation. All other trademarks are the property of their respective owners. n Keep-Alive Power Supplies n Remote Monitoring n Utility Meters n Low Power Industrial Applications
TYPICAL APPLICATION Dropout Voltage/Quiescent Current
500 6
3.3V, 20mA Supply with Shutdown
ILOAD = 20mA 450 DROPOUT VOLTAGE 5 QUIESCENT CURRENT (µA) 400 VOUT IN OUT V 3.3V 350 IN 20mA 4 3.8V TO 1µF 2.2µF 300 45V LT3007-3.3 250 3 IQ SHDN SENSE 200 2 GND 150 DROPOUT VOLTAGE (mV) 100 3007 TA01a 1 50 0 0 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) 3007 TA01b 3007fa For more information www.linear.com/LT3007 1
